[VMG8924-B10A] What is the correct way to report a bug?
rvsjimbo
Just joined John Lewis Broadband in the UK and have been supplied with a VMG8924 B10A, and I have found a bug in the UI of the management interface, which basically requires a factory reset of the router. It is (annoningly) repeatable.
Can someone please tell me the correct mechanism for reporting a (probably) none-security related bug?
Thanks!
Paul.
#SP_Jul_2019
#SP_Jul_2019
Firmware version: 1.00(AAKL.28)C0The issue I have is that if you use a special character (in this case an apostrophe) as part of a WPA2-PSK key (which I have done before on my old DrayTek router), then it prevents any further configuration of the wireless settings by blanking out the band select drop-down - you cannot select either 2.4 or 5GHz. This is definitely repeatable and I have done it again just now (after making a backup of the working configuration this time.The good news (again just tested) is that bringing configuration back from a backup sorts the problem. Previously I was only able to fix it via a factory reset.Feel free to give me some test firmware to try, and I will see if it gets rid of the problem.Best regards,Paul.0
Hi rvsjimboIn FW AAKL28C0, I have tried in my side but I cannot duplicate the issue symptom.1. Go to wireless > general > WPA2-PASK change password = '1234567892. There's has a pop up window remind me WPA Pre-Shared Key should be between 8 and 63 characters(a-z, A-Z, 0-9, '-', '_' and '.') or 64 hexadecimal digits.3. Close this window and follow the suggestion set password = 1234567890, GUI page works normally.Please advise me which step I missed? Thank you.0
Well, it looks like the ZyXel simply does not like apostrophes, i.e. 'So, I will stay away from those. Although I will try it again when I see a new software revision come out.Something else that I think I cannot do with the ZyXel is run a VPN server, is this correct?Thanks!Paul.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
