How to disable myZyxelCloud when launch iOS app
Legis
Legis Posts: 11 image  Freshman Member
Third Anniversary
edited July 2019 in Multy WiFi System
it quite annoy.
I do not want to register it.
How to disable the toast window.
#MultyX_Jul_2019
  • Teemo
    Teemo Posts: 55 image  Ally Member
    Do you mean Multy App or ... ?
    Any screenshots?
  • Legis
    Third Anniversary
  • workinto
    workinto Posts: 44 image  Freshman Member
    First Answer First Comment First Anniversary
    edited July 2019
    You can just simply press the "X" at the corner, and this message will not show again.
    However, there are few features will require an account.
  • Legis
    Third Anniversary
    I did.
    But it pop up every time when it launch
  • workinto
    What's the Firmware of Multy App?
    I tested it on my iPhone, and this message never pops up.
  • Legis
    Third Anniversary
  • JamesL
    JamesL Posts: 38 image  Freshman Member
    @Legis
    This is a system default setting, it will only pop up when you open this App.
    After you chick the "X", it will never pop up again, unless you clean the cache of this app, and reopen it.
  • Legis
    Third Anniversary
    There is no cache clean on iOS. I reopen everyday it still there.
