NAS326 Frage zu Entware, Meta-Repository
Roberto8
Roberto8 Posts: 3 image  Freshman Member
edited March 2019 in Personal Cloud Storage
Ich habe Entware installiert. Entware hat kein Icon?
Aber die Package-Liste ist leer, Fehler 404.
Außerdem:
root@NAS326:/# opkg update
-sh: opkg: command not found
Was kann ich tun. Habe schon mehrmals Entware installiertund deinstalliert - aber ohne Erfolg.
Vielen Dank für Eure Hilfe
Gruß Robert
#NAS_Mar_2019
«1
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    It's right that there is no icon. And also that the packages page in the webinterface gives a 404. The latter is caused by an automagic update to Entware 3, which confuses the web backend. That's only cosmetical, though.
    Your actual problem is probably caused by the package profile-hook not being installed. More info here:
  • Roberto8
    edited March 2019
    How to install Profile-Hook??
    The link does not include how to install the missing profile hook. Also anywhere else on the Internet to find. Funny that only I have this problem. Today I again took a new hard drive and rebuilt Zyxel-Nas - same problem. Why does not work.
    Profile Hook is not installed and not documented.
    I hope someone can help me, or how do the other users?
  • Mijzelf
    <div>su<br></div><div>/opt/bin/opkg update</div><div><br></div><div>/opt/bin/opkg install profile-hook</div>
    That thread I pointed to is from another 326 having the same problem. May the oldest logfile (downloadable via the webinterface) can tell why it doesn't work.
  • Roberto8
    edited March 2019
    Unfortunately, no success!
    ~ # /opt/bin/opkg update
    Updated list of available packages in /opt/var/opkg-lists/entware
    Collected errors:
     * opkg_conf_parse_file: Duplicate src declaration (entware http://bin.entware.net/armv7sf-k2.6). Skipping.
    ~ # /opt/bin/opkg install profile-hook Unknown package 'profile-hook'. Collected errors: * opkg_conf_parse_file: Duplicate src declaration (entware http://bin.entware.net/armv7sf-k2.6). Skipping. * opkg_install_cmd: Cannot install package profile-hook. ~ #
  • Mijzelf
    I think your /opt/etc/opkg.conf file is corrupted. The Entware-ng package installs Entware-ng, but meanwhile Entware-ng is deprecated, and updates itself to Entware during install.
    I have fixed that problem, but it's not thoroughly tested, and the package is only available using the zyxel.diskstation.eu repo.
    The contents of the file on my system are:
    src/gz entware http://bin.entware.net/armv7sf-k2.6<br><div>src/gz Mijzelf http://downloads.zyxel.nas-central.org/Users/Mijzelf/Entware-ng/binaries/armv7<br>dest root /<br>dest ram /opt/tmp<br>lists_dir ext /opt/var/opkg-lists<br>option tmp_dir /opt/tmp<br>arch all 100<br>arch armv7soft 150<br>arch armv7-2.6 160<br></div>
  • Roggenkeil
    Roggenkeil Posts: 6 image  Freshman Member
    I already tried a clean install and am using the correct repo (disk station)
    Opened logfile at Tue Jul 30 21:20:10 IDT 2019
    Flushing memory buffer
        Starting up
    Flushing done
    [21:20:10] Create symlink /opt -> /i-data/df3086ca/.PKG/Entware-ng/opt
    [21:20:10] /opt/etc/init.d/rc.unslung is not available, start installer
    [21:20:10]     Info: Opkg package manager deployment...
    [21:20:10]     Connecting to pkg.entware.net (104.27.177.50:80)
    [21:20:10]
    opkg                 100% |*******************************|   124k  0:00:00 ETA
    [21:20:11]
    opkg.conf            100% |*******************************|   142   0:00:00 ETA
    [21:20:11]     Connecting to pkg.entware.net (104.27.177.50:80)
    [21:20:11]
    libgcc_s.so.1        100% |*******************************| 49120   0:00:00 ETA
    [21:20:11]
    ld-2.22.so           100% |*******************************|   131k  0:00:00 ETA
    [21:20:12]
    libc-2.22.so          34% |**********                     |   412k  0:00:01 ETA
    libc-2.22.so         100% |*******************************|  1198k  0:00:00 ETA
    [21:20:12]     Info: Basic packages installation...
    [21:20:12]     Downloading http://pkg.entware.net/binaries/armv7/Packages.gz.
    [21:20:12]     Updated list of available packages in /opt/var/opkg-lists/packages.
    [21:20:13]     Installing libc (2.23-6) to root...
    [21:20:13]     Downloading http://pkg.entware.net/binaries/armv7/libc_2.23-6_armv7soft.ipk.
    [21:20:13]     Installing libgcc (6.3.0-6) to root...
    [21:20:13]     Downloading http://pkg.entware.net/binaries/armv7/libgcc_6.3.0-6_armv7soft.ipk.
    [21:20:15]     Configuring libgcc.
    [21:20:15]     Configuring libc.
    [21:20:15]     Installing libpthread (2.23-6) to root...
    [21:20:15]     Downloading http://pkg.entware.net/binaries/armv7/libpthread_2.23-6_armv7soft.ipk.
    [21:20:16]     Configuring libpthread.
    [21:20:16]     Installing entware-opt (222108-6) to root...
    [21:20:16]     Downloading http://pkg.entware.net/binaries/armv7/entware-opt_222108-6_armv7soft.ipk.
    [21:20:17]     Installing libssp (6.3.0-6) to root...
    [21:20:17]     Downloading http://pkg.entware.net/binaries/armv7/libssp_6.3.0-6_armv7soft.ipk.
    [21:20:17]     Installing librt (2.23-6) to root...
    [21:20:17]     Downloading http://pkg.entware.net/binaries/armv7/librt_2.23-6_armv7soft.ipk.
    [21:20:17]     Installing libstdcpp (6.3.0-6) to root...
    [21:20:17]     Downloading http://pkg.entware.net/binaries/armv7/libstdcpp_6.3.0-6_armv7soft.ipk.
    [21:20:18]     Installing ldconfig (2.23-6) to root...
    [21:20:18]     Downloading http://pkg.entware.net/binaries/armv7/ldconfig_2.23-6_armv7soft.ipk.
    [21:20:19]     Installing findutils (4.6.0-1) to root...
    [21:20:19]     Downloading http://pkg.entware.net/binaries/armv7/findutils_4.6.0-1_armv7soft.ipk.
    [21:20:19]     Installing terminfo (6.0-1c) to root...
    [21:20:19]     Downloading http://pkg.entware.net/binaries/armv7/terminfo_6.0-1c_armv7soft.ipk.
    [21:20:19]     Installing locales (2.23-6) to root...
    [21:20:19]     Downloading http://pkg.entware.net/binaries/armv7/locales_2.23-6_armv7soft.ipk.
    [21:20:20]     Installing opkg (2011-04-08-9c97d5ec-17a) to root...
    [21:20:20]     Downloading http://pkg.entware.net/binaries/armv7/opkg_2011-04-08-9c97d5ec-17a_armv7soft.ipk.
    [21:20:21]     Entware uses separate locale-archive file independent from main system
    [21:20:21]     Creating locale archive - /opt/usr/lib/locale/locale-archive
    [21:20:21]     Adding en_EN.UTF-8
    [21:20:27]     Adding ru_RU.UTF-8
    [21:20:34]     You can download locale sources from http://pkg.entware.net/sources/i18n_glib223.tar.gz
    [21:20:34]     You can add new locales to Entware using /opt/bin/localedef.new
    [21:20:34]     File /opt/etc/opkg.conf upgraded, new repository set!
    [21:20:34]     Please run opkg update + opkg upgrade once more
    [21:20:34]     Configuring libssp.
    [21:20:34]     Configuring librt.
    [21:20:34]     Configuring terminfo.
    [21:20:34]     Configuring ldconfig.
    [21:20:34]     Configuring locales.
    [21:20:34]     Configuring opkg.
    [21:20:34]     Configuring libstdcpp.
    [21:20:34]     Configuring findutils.
    [21:20:34]     Configuring entware-opt.
    [21:21:37]     wget: can't connect to remote host (23.141.224.195): Connection timed out
    [21:21:37]     Collected errors:
    [21:21:37]     * opkg_download: Failed to download http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv7/Packages.gz, wget returned 1.
    [21:21:37]     Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
    [21:21:37]     Updated list of available packages in /opt/var/opkg-lists/entware
    [21:21:37]     Downloading http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv7/Packages.gz
    [21:21:37]     *** Failed to download the package list from http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv7/Packages.gz
    [21:21:38]
    [21:21:38]     Collected errors:
    [21:21:38]     * opkg_install_cmd: Cannot install package profile-hook.
    [21:21:38]     Unknown package 'profile-hook'.
    [21:21:38]     Info: Congratulations!
    [21:21:38]     Info: If there are no errors above then Entware-ng was successfully initialized.
    [21:21:38]     Info: Found a Bug? Please report at https://github.com/Entware-ng/Entware-ng/issues
    [21:21:38] Execute /opt/etc/init.d/rc.unslung start
    [21:21:38] Done /opt/etc/init.d/rc.unslung start
    Closed logfile at Tue Jul 30 21:21:38 IDT 2019
    I posted my log file I think in the end the problem "unknown package 'profile-hook'" appears.
    What is the exact solution to use opkg properly?
    Thanks in advance! :-)
  • Roggenkeil
    I have got the same problem as Roberto8 on a clean NAS540.
    Here my log:
        Starting up
    Flushing done
    [21:20:10]
    [21:20:11]
    [21:20:11]
    [21:20:11]
    [21:20:12]
    [21:21:38]
    What is the exact step-by-step-solution for this issue? I do not get your last comment, mijzelf to be honest.
    Thanks in advance!
  • Mijzelf
    edited August 2019
    That looks OK, except that it tries to use nas-central.org, which is down.
    To solve that, you have to edit /opt/etc/opkg.conf , and change
    in
    After that you can execute
    <div>/opt/bin/opkg update</div><div><br></div><div>/opt/bin/opkg install profile-hook<br></div>
    After logging out and logging in again the problem should be solved.
  • Roggenkeil
    edited August 2019
    I am going to try that! Thank you very much!
    Aaaaand works! :)
    Edit: Ok, at least I thought it would. But still after login I get the error -sh: opkg: not found :(
  • Mijzelf
    Long shot, you have also installed ffp? If yes, read the page on the Entware-ng webpage about ffp and Entware-ng coexisting.
