Multy U Ethernet Backhaul Problem
bbhh
I have two Multy U in my network. Primary one is connected to a switch. Modem with internet access is also connected to same switch. Secondary Multy U is operating with Wifi Backhaul with no problem. However I want to use Ethernet backhaul to improve performany of the secondary even more.
Problem: The moment I connect the WAN port of the secondary Multy U to the switch for ethernet backhaul, the LED turns red, inficating no internet connection.
This seems to be a new thing after yesterdays firmware upgrade, however not sure if things are in connection with that upgrade.
Comment: I use Multy U in Bridge mode. DHCP is my Router/ Modem connected to the switch.
Do you have any idea whats the problem here and how I can use ethernet backhaul in my network?
Thanks very much for your ideas on this.
Best,
bbhh
#MultyU_Aug_2019
Best,
bbhh
#MultyU_Aug_2019
According to your description, your topology will look like this:
Modem -----Switch-------Primary Multy
|------------Second Multy
It's incorrect, please follow below link to set up your system.
https://homeforum.zyxel.com/discussion/2548/how-to-set-up-multy-u-wsr30-with-ethernet-backhaul#latest
PS, you will have to reboot both Multys after you set them in a correct way.
Thanks for your reply. However, the setup shown is not exactly the one that I have. In the scenario shown, the modem is directly connected to primary Multy U. In my case Modem and primary Multy U is connected to switch.
Does this make a difference?0 -
Just tried it as described. The moment I restart the second Multy U with Ethernet Backhaul, both led go red.
Any thoughts on this?0 -
The topology should be like this.
Modem<LAN>----Switch-----<WAN>Primary Multy<LAN>-------<WAN>Second Multy
Or
Modem<LAN>----Switch-----<WAN>Primary Multy<LAN>----Switch-----<WAN>Second Multy
Please reboot them without Ethernet backhaul, then plug the cable after they boot up.
If the second Multy is very far from the primary one, please wait for the primary one boots up.
Next, connect the Ethernet cable before the second Multy bootup.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 318 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
