Error when setting up log emailing on NSA320
Sourface
I'm wanting to mail my logs daily. I've setup my NAS540 and it works perfectly. I receive an email daily at 3:00PM. When I configure my NSA320 with the exact same information I get the error "Send test email result: Error, String not found! Do you want to apply the settings?" Does anyone here have an idea? I know the NSA320 is "End of life". I have the last firmware update installed. Aside from this, it is working perfectly in Raid 1 with two 8 terabyte drives.
#NAS_Aug_2019
#NAS_Aug_2019
Best Answers
lodiabaiYour suggestion got me to try new things.I eventually got the NAS540 to work with the gmail smtp server. I then tried it on the NSA320 and it worked also. Now it must be down to an incompatibility on the smtp server I was originally using.1
I found the Zyxel KB about the setting Gmail of log report.
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=014956&lang=EN0
Can you share the screenshots?
Did you try to use another mail to test?0 -
Here is a screenshot. All the information on the NSA320 is the same as on the NAS520 which works. I tried to use the gmail smtp server but that failed on the NAS520 with a different error. So, I didn't try it on the NSA320.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
