NAS 326 / rsync
komak
komak Posts: 3 image  Freshman Member
edited August 2019 in Personal Cloud Storage
Hi, I have my first nas and I don't now, how to send files from linux to nas through rsync. Rsync is missing on nas side and I don't now, how to install. When I try send files to nas, I get error message:
$ rsync ./* admin@192.168.1.3:/i-data/e75a191a/admin
admin@192.168.1.3's password:
sh: rsync: not found
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(226) [sender=3.1.1]
Can me somebody help?
#NAS_Aug_2019
Best Answers
  • Mijzelf
    Mijzelf Posts: 2,998 image  Guru Member
    rsync is in the package 'RandomTools', which can be installed by installing 'MetaRepository'.
  • komak
    I don't find RandomTools in App Center. How can I install MetaRepository and Random Tools? Apt or yum is not available..
  • Mijzelf
    You didn't see the hyperlink under 'MetaRepository' in my previous post?
  • komak
    Sorry! Yes, I didn't see hyperlinks in text. It is working perfect. Thank You very much.
  • Ghislain
    Ghislain Posts: 1
    What to do after having installed MetaRepository?
  • Mijzelf
    Install RandomTools. Then you have the rsync available on the commandline.
  • hazimozi
    hazimozi Posts: 17 image  Freshman Member
    Is it possible to install these packages to a system without batches added (system runs on RAM disk)? Maybe I should add a pendrive before?
