I need the firmware upgrade for VMG1925-T20K...
compusys
#SP_Aug_2019
#SP_Aug_2019
Hi compsuys
May we know where you get the VMG1925-T20K from?
If your VMG1925-T20K was from your ISP, it might be a customized firmware version and controlled by the ISP.
You need to check with your ISP for firmware upgrade.
If you bought the VMG1925-T20K by yourself, may we know what is the firmware version your VMG1925-T20K is using now?0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
