Bricked Zyxel Aurora camera after firmware upgrade
Koray
Posts: 2 Freshman Member
I just bought a zyxel aurora cam and alarm unit. Alarm unit did not work so i tried to start a firmware upgrade from my mobile phone. Now aurora cam does not start, it's led just lights up white and stays that way. I found firmware from the product page but there are no instructions to write firmware to aurora camera manually.
#Others_Aug_2019
#Others_Aug_2019
When you open Aurora App, does it show camera online or offline?
Is Zyxel Aurora Cloud Access Camera able to reset and reinstall?
I check the definition of LED, white means ready to record videos in low light.
Thank you for your reply. Aurora app does not show camera at all. I couldn't be able to reset and reinstall firmware, tried to press on-off button on the camera for the various durations with no success.. I can only shutdown camera by pressing power button for 10 seconds, thats all. I believe there was a problem with firmware update and now camera is bricked somehow. I wonder if it's possible to connect it to a computer in DFU mode.0
Here is the reset information from User's Guide.
Please make sure press the power button until you hear two beeps. If it still not works, I suggest you to contact ZYXEL local support.
- 383 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 204 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
