AMG1302-T11C firmware upgrade problem
PolarizedIons
Posts: 3 Freshman Member
Hi, I have a AMG1302-T11C router/modem that I am trying to upgrade the firmware of. I'm currently running V3.00(ABCG.11)H0.
When going through zyxel.com -> support -> download library... I get to https://www.zyxel.com/osearch/dl-search.aspx?mci_country=za&mci_lang=en&keyword=amg1302&submit=Search, which lists the latest firmware as v3.00(ABCG.11)H0 (16-10-2017) (sidenote: googling that firmware version only has 2 results, so I'm sure it's special)
However, just going through google, I get to https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-02433&md=AMG1302-T11C , which lists the latest firmware as v3.00(ABCG.13)C0 (May 29, 2018).
At some point I know I downloaded a firmware update, and I'm pretty sure it is the first one.
Now my problem: I can't seem to update past that version. Trying to update to the newer v3.00(ABCG.13)C0, or even v3.00(ABCG.11)C0 just causes the router to reboot, not updated.
Is there any way to update the router to a newer version? Or am I stuck with this outdated version?
Thank you
#CPE_Nov_2018
#CPE_Nov_2018
Hi PolarizedIons,
V3.00(ABCG.11)H0 is customized configuration, you cannot use v3.00(ABCG.11)C0/ v3.00(ABCG.13)C0 on your device. If you need newer fw (H0), please contact with your ISP to have it.
HiI did not buy this router/modem from my ISP.I did not download that custom firmware from my ISP.My ISP does not have any firmware to download anywhere.0
Hi PolarizedIons,
May I know where you get your device? And please provide serial number for checking. (Serial number is on label of your device)
A local shopping website, Takalot.com (similar to Amazon I guess)SN: S162E520362300
Hi PolarizedIons,
Your device is installed on customized fw so it’s impossible to change to C0 version. May I know if any issues you encounter?
Hi amiradnanThis topic depends on how you received the internet service. The device config needs to match your service provider.0
I have the same problem. I own this router, which was previously on V3.00(ABCG.11)T0 because it was used for an ISP connection. I now want to change that to the V3.00(ABCG.11)C0 firmware but the router will not accept it. As you said, "The device config needs to match your service provider." That is what I want to set up, how do I install the manufacturer firmware so I can enable this please?0
Your device just hacked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Check here-1
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
