NSA325 V2 Largest harddrive for this Nas
wiimad
Hi i currently have this nas with 2 x 4TB drives.
The drive is using the latest firmware V4.81(AALS.1), I would like to upgrade to 2 x 12TB drives.
Can you tell me if the drives will be accepted into the enclosure and if not what is the maximum drive capacity allowed or is it a case of trial and error rather than firmware limitations?
#NAS_Sep_2019
#NAS_Sep_2019
thanks for the info mel
You can check its "Datasheet" about "Hardware Specifications".
https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=M-01820&md=NSA325%20v2#searchZyxelTab2
You also can refer to this topic.
https://homeforum.zyxel.com/discussion/2385/nsa325-v2-upgrade-to-maximum-raid1-capacity
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
