VMG8825-B50B wake on lan (wol) configuration
nonchiedercilaparola
hi, does anyone know how to configure wake on lan on this device VMG8825-B50B? i can't find anythings useful from web ui interface, only a section where i can weke up a device connected in my lan but this only a test tool and not place where i can save wol configuration.
regards
Luigi
#SP_Sep_2019
regards
Luigi
#SP_Sep_2019
Hi nonchiedercilaparola
May I ask what device or OS you want to wake up? does device network card set up ready? Normally our CPE does not block the magic packet, but we can discuss what device/ tool you are using.
hi, i'm on macbook pro a1278 (late 2011). From info mac pannel i see that wol option is active. i try some android app to wake up my mac fron outside of my network but nothing0
Macbook pro a1278 is the only failed device? I may need some time to find one to test if you have other failed case please let me know
i have only this computer at home. so router-modem-ap zyxel is ready to wol without setting changes? My issue is due to my macbook?
from my adroid phone i test serveral wol app. my goal is to use plex client from my phone to use plex server on my osx
so? are there news about this?0
Hi nonchiedercilaparolaI did the following test, and issue does not happen. WOL works in my side1. Set up an environment with a different router, make sure 2 different laptops can wake up by WOL function.2. Replace step 1 router to a VMG8825-B50B. These 2 different laptops can wake up by WOL function.I may need your help to check if macbook NIC configure correctly
I checked the user manual. Still, can't find how to configure WOL on VMG8825-B50B. Please guide me here.I've a Macbook pro.Zach Swedberg
I checked the user manual. Still, can't find how to configure WOL on VMG8825-B50B. Please guide me here.I've a Macbook pro.https://community.zyxel.com/en/discussion/8101/router-vmg8825-b50b-port-forwarding-not-working https://writemyessaysonline.com
-1 -
There are a few ways to make supplemental income as a writer. One option is to sell your work to magazines or other publications. You can also give readings or workshops, or sell your work online. Finally, you can also seek out freelance writing opportunities.
-1
- 588 USG FLEX H Series
- 477 News and Release
