[NAS542] Slow speed with nfs
vidra
I am experiencing an issue: my transfer speeds are very slow (~50MB/s) and I cannot figure out why.
My exports look normal and the only thing I have changed is sync to async to see if i would make a difference(it does not). The problem is quite strange because the speed (when I test it) jumps to 1.5GB/s and then the transfer stops until it just jumps to finished. My average then is around ~50MB/s. This happens if I test with dd or just a file copy with thunar.
I find this very strange, and I must mention that when I was using my older NSA325 with the same disks I did not experience anything like this.
Does anybody know what is going on and how I can fix this. i should also point out that i cannot mount nfsv4 - if that is related.
Thank you for your help!
Edit 1. : I have reinstalled NFS from app center and now nfsv4 works, the speed is still the same. And I have noticed that my cpu usage (on nas) goes to 97% with nfsd being 70%, i doubt that this is normal.
Edit 2. : I have tried to transfer data back to my pc and the speed is normal (110+ MB/s), cpu usage is also not high.
#NAS_Aug_2019
#NAS_Aug_2019
Linux caches in RAM the data written to disks, also for network mounted disks (NFS), so you see 1.50 GB/s at the beginning because of caching.
If you are using a HDD I think that 50 MB/s speed is due to HDD writing speed and not so speedy hardware ff the NAS.
Read speed is always higher for any disk, also SSD.
I was using the same disk with NSA325 and I was getting full gigabit. Is there a way to set up ssd caching with nas542?Edit: I installed an SSD in to the NAS and the speed is the same (~50MB/s). So it is not the disk that is not preforming well.
Could mtu be the problem ( i can't set it higher than 1500 on nas) and I can not enable/find jumbo frames in web interface .Changed mtu to 9000 on all devices. Speed is the same. My load average is 3.76 which is a bit strange0
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 322 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
