LTE3302 lease failed
yanduin
Posts: 2 Freshman Member
Hi everyone! Hopefully someone has experience with this LTE router and can help me get a working connection on it.<br><br>The router is successfully picking up the correct network, submitting the correct username, password, and number. After this, it fails to obtain a lease.<br><br>Has anyone got any solutions or advice? Thanks!<br><br><img alt="" src="https://us.v-cdn.net/6029482/uploads/editor/dc/4mitru167lgr.png">
#SP_Sep_2019
Hi Yanduin,
Could you please check with your service provider about the correct APN profile settings?
I test my LTE3302 with an incorrect APN profile for my SIM card and I find the same logs on my unit as yours.
If it'd be not easy to check with your service provider, maybe you can start with the following settings:
Scenario 1 Configure the "Dial-Up Profile" to "Manual" and leave the APN profile blank
Scenario 2 Configure the "Dial-Up Profile" to "Manual" and set the APN as "live.vodafone.ie", both Account and Password as "dublin".
https://wiki.apnchanger.org/Ireland#Vodafone
Regards,
Bob0
Hi Yanduin,
Regards,
Bob0 -
Thanks so much for the advice, Bob.
I had previously tried autodetection, and I had tried manually entering the APN with passwords of 'vodafone' and 'vodafone', which were provided by the operator.
When i followed your advice of marking the provider as 'Other', with no other details, it worked straight away. You're a scholar!0 -
As long as the gateway supports “multi-WAN fail-over”, you can just connect the Zyxel LTE3302 Series to an existing gateway and set LTE as the fail-over WAN. And also you may refer Router Login guide and then try using your LTE router. It might help you in resolving your issue.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
