NSA325 - no volume, no packages
bobby
I had a power failure and had te reset my NSA325 in order to get it back on the network. I had entware setup previously.
Now there seems something wrong.
When I check for firmware update the popup says: Connection to the server hung.
There are no packages on the packages tab and the buttons are greyed out. The message bar at the bottom says: This feature is not available for there is no volume.
The volume section mentions my two disks (jbod), 70% used, message bar at the bottom says: Ready.
In the log section I see 13 comments. The last one, from today reads:
Volume is FULL. It is recommended to reserve freespace for operating system to work properly.
I would like to get my system back to where is was:
- running entware
- sharing my files on the network through nfs
- etc.
I think there is something wrong, but don't know where to start.
Regards, Bobby
#NAS_Oct_2019
- running entware
- etc.
Regards, Bobby
#NAS_Oct_2019
Start with the Telnet Backdoor. If you have managed to get access over telnet, post the output of
ls -l /i-data/<br>ls -l /etc/zyxel/storage/<br>cat /proc/mounts
Hello Mijzelf,
Thank you for the quick reply. Here are the outputs.~ # ls -l /i-data/drwxrwxrwx 21 root root 4096 Sep 4 09:14 58e75e09lrwxrwxrwx 1 root root 25 Sep 13 18:30 md0 -> /etc/zyxel/storage/sysvol~ # ls -l /etc/zyxel/storage/-rw-rw-rw- 1 root root 51 Sep 1 07:10 mduuid.tabledrwxr-xr-x 1 admin everyone 2048 Oct 13 2015 sysvol~ # cat /proc/mountsrootfs / rootfs rw 0 0/proc /proc proc rw,relatime 0 0/sys /sys sysfs rw,relatime 0 0none /proc/bus/usb usbfs rw,relatime 0 0devpts /dev/pts devpts rw,relatime,mode=600 0 0/dev/mtdblock8 /zyxel/mnt/nand yaffs2 ro,relatime 0 0/dev/sda1 /zyxel/mnt/sysdisk ext2 ro,relatime,errors=continue 0 0/dev/loop0 /ram_bin ext2 ro,relatime,errors=continue 0 0/dev/loop0 /usr ext2 ro,relatime,errors=continue 0 0/dev/loop0 /lib/security ext2 ro,relatime,errors=continue 0 0/dev/loop0 /lib/modules ext2 ro,relatime,errors=continue 0 0/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0/dev/ram0 /usr/local/var tmpfs rw,relatime,size=5120k 0 0/dev/mtdblock4 /etc/zyxel yaffs2 rw,relatime 0 0/dev/md0 /i-data/58e75e09 ext4 rw,noatime,barrier=0,data=writeback,usrquota 0 0/dev/mtdblock4 /usr/local/zy-pkgs yaffs2 rw,relatime 0 0/dev/mtdblock4 /etc/zyxel/zy-pkgs yaffs2 rw,relatime 0 0/dev/mtdblock4 /usr/local/apache/htdocs/adv,/pkg yaffs2 rw,relatime 0 0/dev/mtdblock4 /usr/local/apache/web_framework/data/cache yaffs2 rw,relatime 0 0/dev/mtdblock4 /usr/local/apache/web_framework/data/config yaffs2 rw,relatime 0 00 -
/etc/zyxel/storage/sysvol is supposed to be a symlink to the volume. In your case it's a directory. /etc/zyxel/ is the mountpoint of a flash partition, so I think your errorVolume is FULL. It is recommended to reserve freespace for operating system to work properly.is caused because that directory is now treated as volume, and the flash partition is tiny.Solution:
<div>rm -rf /etc/zyxel/storage/sysvol</div><div>ln -s /i-data/58e75e09 /etc/zyxel/storage/sysvol</div><div>reboot</div>
rm -rf /etc/zyxel/storage/sysvol took a while to complete, but no error. ln -s /i-data/58e75e09 /etc/zyxel/storage/sysvol reboot After reboot the device is not on the network anymore. It hasn't receiver an IP from my gateway. Tried manual reboot with the button on the device, but same result. Should I reset it, or would I then be back where I was?
Don't know. How did you reset it last time? Keeping the button pressed until the 3th beep? If not, it was no full reset. AFAIK a full reset puts a new filesystem on the flash, and then I wouldn't expect a timestamp in 2015 on the sysvol symlink.Anyway, when the device doesn't show up in network you don't have much choice, do you? Unless you have a suitable serial cable.1
Well a couple of extra resets (one beep) worked!
Thanks!1 -
I have a similar issue where my NAS doesn't see created volume even if I create new/format hdd. What even more annoying is it looses all settings including network settings after each reboot. Is it fixable ?
Maybe. When it looses it's settings the flash partition clearly doesn't store it. That can be because it's worn out, but maybe it's just a filesystem error. In the latter case a full reset could solve the problem (keep the reset button on the back pressed until it has beeped 3 times. 15~25 seconds).
Reset button worked for my NSA310. It keeps settings now. Thank you again !
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
