Zyxel NAS542 - copied files from old NAS are inaccessible (open from NAS share)
Samba version 4.1.7PID Username Group Machine-------------------------------------------------------------------10221|XXX|everyone|X.X.X.223|ipv4:X.X.X.223:5482510221|pc-guest|everyone|X.X.X.223|ipv4:X.X.X.223:5482510706|pc-guest|everyone|X.X.X.163|ipv4:X.X.X.163:4968711360|XXX|everyone|X.X.X.13|ipv4:X.X.X.13:4917511265|XXX|everyone|X.X.X.237|ipv4:X.X.X.237:6275410706|pc-guest|everyone|X.X.X.163|ipv4:X.X.X.163:4968710221|pc-guest|everyone|X.X.X.223|ipv4:X.X.X.223:5482510967|pc-guest|everyone|X.X.X.250|ipv4:X.X.X.250:5022411553|XXX|everyone|X.X.X.222|ipv4:X.X.X.222:4975111287|XXX|everyone|X.X.X.251|ipv4:X.X.X.251:5571810967|pc-guest|everyone|X.X.X.250|ipv4:X.X.X.250:5022410706|pc-guest|everyone|X.X.X.163|ipv4:X.X.X.163:4968710967|pc-guest|everyone|X.X.X.250|ipv4:X.X.X.250:50224Service pid machine Connected at-------------------------------------------------------share|10706|X.X.X.163|2019-10-07 07:30:23share|11287|X.X.X.251|2019-10-07 07:37:41share|11265|X.X.X.237|2019-10-07 07:37:21share|11553|X.X.X.222|2019-10-07 07:41:40share|10221|X.X.X.223|2019-10-07 07:23:11share|11360|X.X.X.13|2019-10-07 07:38:48share|10967|X.X.X.250|2019-10-07 07:34:12Locked files:Pid Uid DenyMode Access R/W Oplock SharePath Name Time--------------------------------------------------------------------------------------------------10967 502 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy1 Mon Oct 7 10:02:11 201911265 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2018/yyy2 Mon Oct 7 11:24:46 201911287 505 DENY_WRITE 0x120196 WRONLY BATCH /i-data/12344321/share 2019/yyy3/yyy3.dwl Mon Oct 7 07:44:13 201911553 505 DENY_WRITE 0x12019f RDWR BATCH /i-data/12344321/share 2019/yyy4/yyy4.dwg Mon Oct 7 09:08:23 201910706 502 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy5 Mon Oct 7 09:39:14 201911360 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share ___TMP/2019-10-07 Mon Oct 7 08:52:36 201910967 502 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy6 Mon Oct 7 09:21:22 201910221 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy6 Mon Oct 7 10:10:39 201911265 505 DENY_WRITE 0x12019f RDWR NONE /i-data/12344321/share 2019/yyy7/yyy7.xls Mon Oct 7 11:17:18 201911553 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy4/yyy9 Mon Oct 7 10:43:52 201911553 505 DENY_NONE 0x1000a0 RDONLY NONE /i-data/12344321/share 2019/yyy4/yyy8 Mon Oct 7 11:05:21 201911553 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy4/yyy8 Mon Oct 7 11:00:20 201911553 505 DENY_WRITE 0x120196 WRONLY BATCH /i-data/12344321/share 2019/yyy4/yyy8/yyy8.dwl Mon Oct 7 08:41:26 201911553 505 DENY_ALL 0x100080 RDONLY NONE /i-data/12344321/share . Mon Oct 7 10:43:19 201911265 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share . Mon Oct 7 11:24:42 201910967 502 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share . Mon Oct 7 10:01:44 201911287 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share . Mon Oct 7 07:41:42 201911360 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share . Mon Oct 7 07:38:50 201910706 502 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share . Mon Oct 7 09:02:42 201910221 505 DENY_NONE 0x100081 RDONLY NONE /i-data/12344321/share 2019/yyy6/yyy7 Mon Oct 7 09:58:31 2019
Nice forum software, eh?Anyway, is your file listed in the 'Locked files' section? If yes, is the file open on one of the clients listed above?0
Yeah, it is just greatNice forum software, eh?
Anyway, is your file listed in the 'Locked files' section? If yes, is the file open on one of the clients listed above?Will try to check all the stuff in next days - i'm working on this server remotely (so i dont know if it is opened). Strange that I can see in the first section the same PID with different users (guest+full access account) and in third section (Locked files) I see different 'DenyMode' (none / write / all). I'm quite new to this type of 'problem solving' for fixed NAS servers.
Maybe it will be faster to make 'everything' from the beginning?
This is 'local' server (no access from outside), with no need for different users (everyone need full permissions to all files). One shared folder.
Maybe you know the best way to make this? I'm wondering if Zyxel was the good choice (after all the problems)...
and in third section (Locked files) I see different 'DenyMode' (none / write / all)The 'deny mode' depends on the rights of the client, and the tool used to open the file. If it's a viewer which only reads, the file is opened ro, and the sharing is possibly DENY_NONE. if the viewer doesn't care the file can change while it's open. An editor wants to hve exclusive write access, and so the file will be marked DENY_WRITE for the others.Of course a file can have one exclusive write access and several read only accesses simultaneously.In your case I'd first try to close the guest account, I think. As you already found there are clients which have a guest session and a normal session at the same time. So which account is used to open the files?
Thx Mijzelf for all the support, guest accounts were because old windows credentials - changed them
as for the files it was program fault not the server
- 243 Nebula Ideas
- 6.8K Security
- 784 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
