Removed 2 HDD´s can´t access them anymore - NAS542
McPervert
So basically i removed two hdd´s while the NAS was shut down.
I plugged the disks back in but now i can´t access the data anymore. I can see the volumes in the storage manager but the only thing i can do is to create a new volume.
Before i removed them they were just used as network storage, but tbh i can´t tell anymore if i used them as "basic" drives or if i put them in raid.
Anyone got a clue?
#NAS_Oct_2019
Anyone got a clue?
#NAS_Oct_2019
You can see the volumes? In that case the volumes are assembled. Have a look in the shares menu if you have to re-enable the shares on that volumes.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
