Exibel WRE6505 V2, Problems on MAC setup
tknag
When setting up this repeater on MAC the correct web adress is http://zyxelsetup.local.
The user guide that was in the box has not the the ".local" in the sheet...
Furthermore - after writing the correct and excisting password of both 2,4GHZ and 5GHZ wifi in the house 10-20 times i gave up the setup with my Macbook.
Tried setup with an old XP laptop - the same password was accepted - and I was up and running in 2 minutes.
Anyone else had problems regarding zyxelsetup not accepting correct wifi password when setup of the repeater with MAC ?
That is weird as only MacOS not working.
What is your MacOS version?
Have you tried to upgrade the device to latest version?
I have the same problem. Please help.
I have upgraded the device. Nothing helps.
The device is piece of garbage. My network works totally fine when I plug it out. I use this on extender mode.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
