SQUID PROXY SERVER on nas 326
energy1959
energy1959 Posts: 9 image  Freshman Member
edited November 2019 in Personal Cloud Storage
hello everyone, I need instructions for how to install squid proxy server on nas326. Ty very much all friend
#NAS_Nov_2019
«1
  • Mijzelf
    Mijzelf Posts: 3,074
    image  Guru Member
    You can install MetaRepository to install Entware-ng, which will automagically be upgraded to Entware, on which you can install Squid.
  • energy1959
    yes installed, and software enabled on the nas, launched, but not see any app squid inside ty MiJzelf for your great support
  • energy1959
  • Mijzelf
    image  Guru Member
    The Entware package system doesn't have a webinterface. You'll have to login over ssh, as root, and execute
    <div>opkg update</div><div><br></div><div>opkg install squid</div>
  • energy1959
    connected via putty on the nas via ssh connection , root privileges, opkg update     COMMAND NOT FOUND ???
  • energy1959
  • Mijzelf
    image  Guru Member
    In the webinterface provided with the Entware-ng package, read the chapter about FFP and Entware-ng coexisting.
  • energy1959
    ia have read, but I did not succeed
  • Mijzelf
    image  Guru Member
    Permission denied.
    You should login as root.
  • energy1959
    i am inside  opkg update - response command not found ..... i have removed ffp now what commands do I have to give ty very much
