Have a Zyxel Multy-'slave' has a line out to a wired device. All works but app shows it is 100Mbps
AndyS
Is it right that the 2ndary unit the line out is at 100 mbps not the 1000 mbps?
#MultyX_Nov_2019
https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-X/specifications
The ports of Multy X are supported 10/100/1000 Mbps.
Normally, if the connected device and Ethernet cable supports 1000 Mbps, it should use the speed: 1000 Mbps for communication.
What is your network topology?
Did you try to use another Ethernet cable?
Can you share what kind of device is connected to 2nd node via wired and got 100 Mbps?0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
