NAS520 Download Service not working with torrent files.
JOYMAT
i have problem with my NAS520, i just setup that nas, i give a try to download service and was trying to download torrent file and it failed it wont download even 0.1%. I used then 'Transmission' and there was no problem at all with downloading torrents. Could you tell me what is going on actually.
@EDIT
i will downgrade fw to be sure that this problem is not related to newest fw.
#NAS_Nov_2019
@EDIT
#NAS_Nov_2019
Did you disable admin folder? I found the KB: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015998&lang=EN
Did you try to download other torrent files? Is it the same?
My NAS520, Download Service is working properly.
Maybe you should check your setting or try to reset NAS520.
I did not tuch privileges for admin folder. Checked that and admin and root has 777 to admin folder.0
Not sure what kind of setting you did to cause this problem.
Please reset your NAS520, then try again. Otherwise, please use Transmission to download torrent files.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
