VMG8924-B10A, No Remote MGMT
icealec
icealec Posts: 2 image  Freshman Member
edited November 2019 in Smart Home Product
HI.
I cannot connect to my VMG8924-B10A router anymore. I think I was hacked as my DNS on my router kept on being changed. So I wanted to remove any remote access to my router. I logged in and unticked everything on the Remote MGMT tab. I did not think this will also lock me out of the router. Is there any way I can get access back onto my router. Any help will be appreciated.
Thanks Alec
#SP_Nov_2019
  • Hummel
    Hummel Posts: 212 image  Master Member
    @icealec,
    Have you tried to reset it to factory default settings?
  • icealec
    @Hummel
    That is what I'm trying to avoid. I don't have all the setting I need to get it back to 100% working. So if I can avoid it I will be happy.
  • KRAM
    KRAM Posts: 1 image  Freshman Member
    Reset the log-on from your provider log-on/pass to YOUR log/pass (NAME@provider.com and PASS).
    Go to "Network Setting"->"Broadband"->modify(edit) VDSL and change PPP user name/PPP pass.
