NAS520: Restore access to lost volume/disk 1 [SOLVED]
OK, the raid header of the data partition is where I expected it, and it healthy. That is good news. The raid header of the firmware partition is corrupted. maybe because it has contained an extended partition table, maybe because of the root cause of your problem (Whatever happened before you lost your data array?)I prepared a partition table which should fit your disk, which I attached. Unzip it, and put it on your NAS. When you are using Windows, you can use WinSCP for that, and put it in the /tmp/ directory.Then execute
<div>dd if=/tmp/gpt of=/dev/sda</div><div><br></div><div>reboot</div>
It is possible that after the reboot everything will work, it's also possible that we will have to create new raid arrays for firmware, and maybe also for swap. Whencat /proc/mdstat
doesn't show 3 arrays, some extra actions are needed.1 -
/tmp # dd if=/tmp/gpt of=/dev/sda<br>128+0 records in<br>128+0 records out<br>65536 bytes (64.0KB) copied, 4.177463 seconds, 15.3KB/s
</code><pre class="CodeBlock"><code> cat /proc/mdstat<br>Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]<br>md2 : active raid1 sda3[0]<br> 1949383488 blocks super 1.2 [1/1] [U]<br><br>md1 : active raid1 sda2[0]<br> 1998784 blocks super 1.2 [2/1] [U_]<br><br>md0 : active raid1 sda1[0]<br> 1997760 blocks super 1.2 [2/1] [U_]<br><br><div>unused devices: <none></div>It worked! The NAS finds the internal HDD again. Everything seems normal.Thanks a lot! And seriously, where and how can I donate for all the work you have done for me and many others on this and the old forum?What did a do? I fixed a 2 USB flash drives, which were totally corrupted. Windows wouldn't recognize the USB Flash drive, or it took over 20+ minutes to recognize it and then immediately (r)ejected them making them totally unusable.I was able to rescue the flash drives under Linux on the NAS.After a reboot [previous reboots went all fine] of the NAS the internal HDD was no longer recognized. Probably a typo with potentially huge consequences.0 -
The rescue involved overwriting the partition table and filesystem headers on the flash drives, I presume?
I wonder if some extra safety could be reached by changing the rights of /dev/sdb (or whatever device node the USB disk has), and do the action as admin.
where and how can I donate for all the work you have doneWell, you can't donate to me. But, last weekend I upgraded my router to the latest release(candidate) of OpenWRT, and it worked flawlessly, like always. I though I should give them a donation to keep the servers up. But if you want, you can give them a donation on my behalf.
Hi,I have similiar problem, my nas is NAS326, but I suppose it doesn't matter.my data:~ # cat /proc/partitions
major minor #blocks name
7 0 146432 loop0
31 0 2048 mtdblock0
31 1 2048 mtdblock1
31 2 10240 mtdblock2
31 3 15360 mtdblock3
31 4 108544 mtdblock4
31 5 15360 mtdblock5
31 6 108544 mtdblock6
8 0 976762584 sda
8 1 1998848 sda1
8 2 1999872 sda2
8 3 972762112 sda3
8 16 976762584 sdb
8 17 1998848 sdb1
8 18 1999872 sdb2
8 19 972762112 sdb3
9 0 1997760 md0
9 1 1998784 md1
9 2 972630848 md2
9 3 972630848 md3
253 0 102400 dm-0
253 1 972525568 dm-1
253 2 102400 dm-2
253 3 972525568 dm-3
~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid6] [raid5] [raid4]
md3 : active raid1 sda3[0]
972630848 blocks super 1.2 [1/1] [U]
md2 : active raid1 sdb3[0]
md1 : active raid1 sda2[0] sdb2[2]
1998784 blocks super 1.2 [2/2] [UU]
md0 : active raid1 sda1[0] sdb1[2]
1997760 blocks super 1.2 [2/2] [UU]
~ # cat /proc/mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,relatime 0 0
/sys /sys sysfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
ubi4:ubi_rootfs1 /firmware/mnt/nand ubifs ro,relatime 0 0
/dev/md0 /firmware/mnt/sysdisk ext4 ro,relatime,data=ordered 0 0
/dev/loop0 /ram_bin ext2 ro,relatime 0 0
/dev/loop0 /usr ext2 ro,relatime 0 0
/dev/loop0 /lib/security ext2 ro,relatime 0 0
/dev/loop0 /lib/modules ext2 ro,relatime 0 0
/dev/loop0 /lib/locale ext2 ro,relatime 0 0
/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
ubi2:ubi_config /etc/zyxel ubifs rw,relatime 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
~ # mdadm --examine /dev/sd[abcd]3
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 3fa2ac41:656e56d2:686f9f1f:1b51f286
Name : NAS326:2 (local to host NAS326)
Creation Time : Mon May 25 03:57:52 2015
Raid Level : raid1
Raid Devices : 1
Avail Dev Size : 1945262080 (927.57 GiB 995.97 GB)
Array Size : 972630848 (927.57 GiB 995.97 GB)
Used Dev Size : 1945261696 (927.57 GiB 995.97 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : c93ceca9:5ab09837:787ce117:f2a96ff9
Update Time : Tue Jun 30 17:43:12 2020
Checksum : 58295563 - correct
Events : 16
Device Role : Active device 0
Array State : A ('A' == active, '.' == missing)
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : e497df71:99394e60:2cff4d77:9efb710f
Name : NAS326:3 (local to host NAS326)
Creation Time : Sun Oct 29 11:58:05 2017
Raid Level : raid1
Raid Devices : 1
State : clean
Device UUID : 67b61188:5f31e662:1f99eab7:9b372964
Update Time : Tue Jun 30 16:15:22 2020
Checksum : 104b055f - correct
Events : 2
mdadm: cannot open /dev/sdc3: No such device or address
mdadm: cannot open /dev/sdd3: No such device or addressWhat can I do not to lose all data I have on my 2 disks?Please help.TIA
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
