NSA310 Stuck in Reboot Loop
Tyler
My NSA310 starts to boot up, takes a long time then all the lights turn red for a short period.
I had this happen to me years ago and was able to fix the NSA310 using a set of files called universal_usb_key_func This allowed me to stop the boot process with a USB drive and access the NSA310 via telnet. I had saved the website with the directions on how to fix this but it has since been taken down. The post was called NSA310 Stuck in reboot Loop? and was at http://forum.nas-central.org/viewtopic.php?f=249&t=8261
I am hoping someone has these directions saved. I believe it had to do with turning off a function, but I don't remember the commands or what the function was called.
#NAS_Dec_2019
Oh I didn't have the shutdown timer on, but it was scheduled to do a restart on the first of the month. That is probably when this started. What is the commands to fix that?
I tried using your site and force flash to put the latest firmware on. It didn't get me anywhere though.
I saw that it wouldn't flash the firmware, so I tried to downgrade with the same resultled_state_map_addr = 4b
board_model=(A203), file_model=(A203) ... equal!
*** current revision: 49435
*** montavista last revision: 34713
*** it's already new firmware, do nothing here. ***
Kernel checksum pass!
System image checksum pass!
You can erase the configuration, using telnet:cd /tmpmkdir confmount /dev/mtdblock4 confcd conf/conf/rm -rf *poweroff0
back up and runningI will keep the scheduled shutdown features turned off now.Thank you for the help0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 420 News and Release
- 89 Security Highlight
