Unable to login on GS1900-24E after upgrade to GS1900-24E_2.50(AAHK.0)
After upgrading my GS1900-24E with the formware GS1900-24E_2.50(AAHK.0) I am no longer able to login. Before the upgrade the switch had the default user and password admin/1234. After the upgrade I cannot login anymore. Tried a reset, but it does not help. I keep getting "The user name or password is incorrect."
#Biz_Dec_2019
#Biz_Dec_2019
Best Answers
Hi Warnis
We have tried to upgrade our GS1900-24E from FW 2.40 patch 2 to FW 2.50 in our local test.
However, we still can't replicate the issue you have encountered.
In our local lab, we have changed the password.
After upgrading firmware, the switch can still be logged in.
Also, we have tried to reset switch to default and it can be logged in by default account and password.
Therefore, could you help us to provide a video about your process of resetting switch to default?
The video should include how you press the reset button.
Thanks for your cooperation in advance
Zyxel_Derrick
After another reset the switch no longer answered on 192.168.1.1, not even on ping. After a while I found it on 192.168.1.47, and even managed to login with admin/1234. After logging in I could see that it had changed from static addressing (192.168.1.1) to DHCP, why it now had been assigned a dynamic addess.
Since I now was able to login, I could set everything the way I wanted. Why did it automatically change to DHCP? Will that happen again if I reset?
Regards0 -
Hi Warnis
Glad to hear that you can login switch
The current behavior of switch is that when you reset switch or use it for the first time, switch will try to discover if the network environment has dhcp server or not.
If yes, switch will use the ip address that assigned by server.
If no, switch will use 192.168.1.1 as its ip address
Best regards,
Zyxel_Derrick0
Hi WarnisWelcome to Zyxel CommunityNormally, after upgrading firmware and rebooting, switch will run start-up config.If the password had not been changed and saved before, normally it can login with default account and password.Also, you mentioned that you had tried to reset but doesn't work.According to user guide P.34, you have to press the button at the front panel for six seconds until the SYS LED begins to blink and then release.For more details about how to reset to default config, you can download the user guide in the link below and refer to itHope it helpsBest regards,Zyxel_Derrick0
thank you for your quick response.
The reset itself seems to have worked. The IP address
was reset to 192.168.1.1, but I can no longer login when browsing there. I just get "The user name or password is incorrect." when trying to log in with admin/1234, which worked perfectly fine before the upgrade.0 -
Hi Warnis
May I know what kinds of browsers you use?
Also, have you ever tried to use another browser or clear the browser's cache?
If yes, the result is the same?
Zyxel_Derrick0 -
I have used Chrome on windows, IE on windows, Chrome on Android and Samsung browser on Android. Same result everywhere. What should I do?0 -
Hi Warnis
Zyxel_Derrick
Regards0 -
Hi Warnis
Best regards,
Zyxel_Derrick0 -
Good morning. We have the same issue. We have update the GS1900 to to the 2.5 version but we tried to return to the 2.4 version becouse of the RSTP didn`t work (this is other question) and the we could not access to the switch. It seems as the user is not recognized.The zyxel switches (6 units) are the core in our network and we can not update them. Thank you for your assistance.0
Hi rmarmol80
This is the known issue for GS1900 listed in the release note that downgrade from V2.50 to V2.40 and below versions will cause admin account unable to login. This is due to password authentication algorithms are enhanced for vulnerability issues and is not backwards compatible.
Therefore, the only way to login switch after downgrading is to reset switch to default and use default account and password to login.
Best regards,
Zyxel_Derrick
Good morning and thanks your your answer. We have another issue when we try to upgrade the GS1900. We have 5 switches with the 2.4 version. All of them are connected with LAG to create a redundancy among them. To start with the upgrade, we configure first one of them. We dont know why, but the switch goes down due to the spanning tree protocol and we must disconnect one of the redundancy way. The problem can be caused due to they are working with different versions? Have you tested if the LAGs can work with different verions (2.4 and 2.5)?Best regards.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
