Zyxel326 lost settings after reboot and other
nikolae
nikolae Posts: 13 image  Freshman Member
edited December 2019 in Personal Cloud Storage
NAS Zyxel 326, don't know what version of linux is installed:
Linux storage 3.10.39 armv7l GNU/Linux
I have ssh access and after logon I see this message:
BusyBox v1.19.4 built-in shell (ash)
First I notice that, when I made some changes - crontab, edit config file, after nas reboots, changes are lost.
Is there any way to prevent this or somehow to put my settings at system startup?
For example I would like to use daily reports for my hdd smart status.
I make script to receive report and put in to crontab
11 18 * * * /path/hddreport.sh && /bin/cat /path/`date +\%Y-\%m-\%d`-hdd.txt | /usr/sbin/msmtp -a mailjet my@email
I make registration in maiiljet for this purpose. Everything works fine.
From other side, when nas is rebooted it's remember settings - disk volumes, ip's, users and etc...
I found this file, where there is a lot of options setting up, during reboot, but it is Read-only file system.
Have you got any idea, where I can make changes, so after reboot, they will be kept and worked?
Thanks in advance !
#NAS_Dec_2019
Best Answers
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    The NAS is embedded linux system, which has it's own rules. The rootfilesystem is basically an achive embedded in the kernel, which is extracted to a ramdrive. So yes, every change is lost after reboot.
    There are several ways to get around. The most easy way is to install Tweaks, which gives you a way to add cron entries, and RandomTools, which gives you a way to run custom scripts.
    /i-data/sysvol/.PKG/RandomTools/etc/custom_startscripts/ behaves more or less like a 'normal' /etc/init.d/
    To install these packages first install MetaRepository.
  • nikolae
    I put with wget http://http//zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/web_prefix
    into /i-data/0...../admin
    Then login using web gui, select apps - all apps - refresh button twice, but Metarepo
    doesn't show for install, only this message:Download List Success
    Can I put manually this file somewhere?
    http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/NAS326/zypkg/5.21/MetaRepository_20181001_arm_015.zpkg
    and repo be loaded from there?
    So.. can you help me somehow to install it?
    Thanks in advance !
  • Mijzelf
    Any idea where I should put these line for example?
    That's a profile command. You have (at least) 2 options. If you login as admin or root and have installed Tweaks you can give the user a persistent homedir with the 'Change Homedir' tool, and put a .profile there, or, when you installed RandomTools you can put a file in /i-data/sysvol/.PKG/RandomTools/etc/profile.d/, as you can read in the end of /etc/profile
  • Mijzelf
  • nikolae
    Thanks in advance !
  • Mijzelf
    You have to put the web_prefix file in \\<NAS>\admin\zy-pkgs\, or /i-data/../admin/zy-pkgs/
  • nikolae
    For zyxel 326 it says:
    NAS326
    (Firmware 5.10+ only) On this NAS there is no subdirectory zy-pkgs in \\<NAS>\admin\. Just add it.
    I notice that should be in "zy-pkgs" folder - thanks !
    I put this files here: /i-data/040781d8/admin/zy-pkgs
    ZYPKGS
    ZYPKG_INFO.tgz
    control.tar.gz  data.tar.gz (extracted)
    web_prefix
    Also in MetaRepository trying to add this line
    /i-data/sysvol/admin/zy-pkgs/ local
    but still can't see in apps or "Tweaks"
    So.. when metarepo is installed, other apps are stop working like "zcloud"  and "transmission" or I can remove zy-pkg folder it is only for install?
    /i-data/sysvol/.PKG/MetaRepository/etc/init.d
    this is folder that  I should use?
  • Mijzelf
    It doesn't hurt, but the only file needed is web_prefix. (Which, btw, is overwritten by MetaRepository). The rest of the files is ignored. MetaRepositorty creates a subdirectory here which contains it's own database.
    So you have it installed? In that case you only need to refresh the package list. If that doesn't show up more packages, there should be a logfile in \\<NAS>\admin\zy-pkgs\MetaRepository\, showing it's attempts to merge the repo's.
    Unless you have overwritten web_prefix after MetaRepository installed, in that case disable and enable MetaRepository to get the right web_prefix again.
    Nothing stops by default. MetaRepository is just a way to merge the ZyXEL repo with one or more other repos. So you get more packages, not other.
    And no, you can't remove the zy-pkgs folder. The web_prefix file is a detour for the firmware's package system, which is initially used to get MetaRepository installed, but the MR uses it to point to itself.
  • nikolae
    Somehow with enable/disable it works. Now I can see both packages - zyxel and 3rd party.
    Crontab is working.
    alias ll="ls -al"
  • Mijzelf
  • nikolae
    Using "change home dir" tool worked. Second method was not successful.
    Thank you very much for the support !
