Zyxel 326 transmission password
nikolae
nikolae Posts: 13 image  Freshman Member
edited December 2019 in Personal Cloud Storage
Hello
Using Zyxel 326  V5.21(AAZF.5) transmission 2.84 installed.
How to setup http password require when opening
transmission (http://IP_nas:9091) ?
Thanks in advance !
#NAS_Dec_2019
Best Answers
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Transmission has it's own configuration file, which you can find somewhere in /i-data/sysvol/.PKG/transmission/
    Disable transmission, edit the file, and enable transmission.
    For what to edit I refer you to the transmission documentation.
  • nikolae
    Thanks.
    The way you describe it - works
    in settings.json:
    "rpc-authentication-required": true,
    "rpc-enabled": true,
    "rpc-username": "USERNAME",
    "rpc-password": "PASSWORD",
    Thanks again !
  • Godzilla
    Godzilla Posts: 8 image  Freshman Member
    /i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json
  • Mijzelf
  • nikolae
    Thanks.
    in settings.json:
    Thanks again !
  • Godzilla
