Zyxel 326 transmission password
nikolae
Hello
Using Zyxel 326 V5.21(AAZF.5) transmission 2.84 installed.
How to setup http password require when opening transmission (http://IP_nas:9091) ?
Thanks in advance !
#NAS_Dec_2019
Thanks in advance !
#NAS_Dec_2019
Best Answers
Transmission has it's own configuration file, which you can find somewhere in /i-data/sysvol/.PKG/transmission/Disable transmission, edit the file, and enable transmission.For what to edit I refer you to the transmission documentation.0
Thanks.
The way you describe it - works
in settings.json:
"rpc-authentication-required": true,
"rpc-enabled": true,
"rpc-username": "USERNAME",
"rpc-password": "PASSWORD",
Thanks again !1 -
/i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json
Thanks.
in settings.json:
Thanks again !1 -
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
