Expanding volume after hard disks upgrade
I've recently replaced all 4 disks from 1TB to 4TB and rebuild RAID5 (replacing one disk at the time).
It took 5 days to do this and had to do multiple retries to get it done (for some reason it would fail and I had to restart NAS to finish rebuilding RAID5). In the end it worked out fine.
Now I'm trying to expand volume but its not completing and status look like this:
it seems to be working on it but it eventually fails with out providing details
cat /proc/mdstat shows this
~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sda3[7] sdd3[4] sdc3[5] sdb3[6]
11708660736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sda2[7] sdd2[4] sdc2[5] sdb2[6]
1998784 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sda1[7] sdd1[4] sdc1[5] sdb1[6]
1997760 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
cat /proc/partitions
major minor #blocks name
7 0 147456 loop0
31 0 256 mtdblock0
31 1 512 mtdblock1
31 2 256 mtdblock2
31 3 10240 mtdblock3
31 4 10240 mtdblock4
31 5 112640 mtdblock5
31 6 10240 mtdblock6
31 7 112640 mtdblock7
31 8 6144 mtdblock8
8 0 3907018584 sda
8 1 1998848 sda1
8 2 1999872 sda2
8 3 3903017984 sda3
8 16 3907018584 sdb
8 17 1998848 sdb1
8 18 1999872 sdb2
8 19 3903017984 sdb3
8 32 3907018584 sdc
8 33 1998848 sdc1
8 34 1999872 sdc2
8 35 3903017984 sdc3
8 48 3907018584 sdd
8 49 1998848 sdd1
8 50 1999872 sdd2
8 51 3903017984 sdd3
31 9 102424 mtdblock9
9 0 1997760 md0
9 1 1998784 md1
31 10 4464 mtdblock10
9 2 11708660736 md2
mdadm --examine /dev/sd[abcd]3
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 0c7deebc:1fade3f4:1bde3e73:4bcee8ea
Creation Time : Sun Jun 21 04:36:36 2015
Raid Level : raid5
Raid Devices : 4
Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)
Array Size : 11708660736 (11166.25 GiB 11989.67 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 534058d0:e0b0f646:29a981ce:5791da0b
Update Time : Wed Dec 11 19:29:26 2019
Checksum : 682271bd - correct
Events : 1366
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 0
Array State : AAAA ('A' == active, '.' == missing)
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : f522056d:705545a6:8f06f374:21d3820b
Checksum : a37981e - correct
Events : 1366
Chunk Size : 64K
Device Role : Active device 1
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 98c36445:3c29e2e1:1c67c26c:cf29705a
Checksum : 64f0c3c7 - correct
Events : 1366
Chunk Size : 64K
Device Role : Active device 2
/dev/sdd3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 014e806b:6a0740ae:172599c5:a7884f0e
Checksum : 64204930 - correct
Events : 1366
Chunk Size : 64K
Device Role : Active device 3
#NAS_Dec_2019
@Mijzelf
My suspicion was the same and I did the following ( so that other can save some time)
killed all processes that used /dev/md2lsof | grep '/i-data/0c7deebc/' -> will provide the list of all process that needed to be killed
after that I unmounted /dev/md2 and check for errors :
- umount /dev/md2
- check if its still mounted with cmd df -h
- checked for error e2fsck /dev/md2 ( and there where few to say the least)
- and then I resized it resize2fs /dev/md2
- checked for errors again e2fsck /dev/md2
resize2fs /dev/md2
resize2fs 1.42.12 (29-Aug-2014)
The filesystem can be resize to 2927165184 blocks.chk_expansible=0
Resizing the filesystem on /dev/md2 to 2927165184 (4k) blocks.
The filesystem on /dev/md2 is now 2927165184 (4k) blocks long.
Then I restarted NAS (reboot cmd) and voila new volume size and one happy campere2fsck /dev/md2
e2fsck 1.42.12 (29-Aug-2014)
/dev/md2: clean, 211994/731791360 files, 612973016/2927165184 blocks
Its safe to say that zyxel needs to work on GUI so that "normal" users can do this with out falling on linux command line and doing things the "OLD" way
According to your data the raid array is near 12TB, so the array is resized successfully. The problem is in the filesystem which doesn't resize. I think it's not clean, which blocks the resize.I have written about a work-around here:
@Mijzelf
- umount /dev/md2
resize2fs /dev/md2
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
