NAS320 Update drives from 1Tb to 2TB in Raid 1 configuration
metcas
I want to upgrade my Storage in a Raid 1 configuration. Is this the correct procedure
1. Remove 1 drive
2. Insert new 2Tb drive
3. Select Repair option, I assume that this will now be visible in the Volume / Actions column
4. Once repair completed repeat steps 1 - 3 with other drive
How then do I use the full 2Tb ?
Steve
#NAS_Dec_2019
1. Remove 1 drive
Steve
#NAS_Dec_2019
Actually the manual is pretty good! and gives the exact procedure which is as I had thought and then there should be an expand icon to incrase the size of the final raid. section 7.20
- 588 USG FLEX H Series
- 476 News and Release
