Spontaneously reboot
Is the ZyWALL 310 running with UTM functions enabled?If the answer is yes, we already have fix for this reboot issue.I send the date firmware to you via private message for verification.If the answer is no, please also upgrade ZyWALL 310 to the date firmware and give us more information as follows.1. How often did the ZyWALL 310 reboot?2. Use the command to get the disklog and send the disklog to us.Router# show software-watchdog-timer log3. Connect ZyWALL 310 with console using TeraTerm and enter the command.Router> debug kernel console-level 8Then keep collecting console logs and save all console logs to a txt file until the device reboots again.Attached is the document with steps for logging console logs to a file.Emily0
There were no spontaneous reboots after the firmware update.However, if you change the configuration and then restart the device, the changes are not saved.The system status panel, the Boot Status - Fallback to lastgood configuration.It may be the case in the configuration , it is possible as that to check for correctness?
The problem was solved by fixing the configuration file.
Zyxel_Emily said:Is the ZyWALL 310 running with UTM functions enabled?If the answer is yes, we already have fix for this reboot issue.I send the date firmware to you via private message for verification.If the answer is no, please also upgrade ZyWALL 310 to the date firmware and give us more information as follows.1. How often did the ZyWALL 310 reboot?2. Use the command to get the disklog and send the disklog to us.Router# show software-watchdog-timer log3. Connect ZyWALL 310 with console using TeraTerm and enter the command.Router> debug kernel console-level 8Then keep collecting console logs and save all console logs to a txt file until the device reboots again.Attached is the document with steps for logging console logs to a file.Emily
Hi @ewing,
Can you follow Emily’s instruction to help us collect console log for analyzing.Attached is the document with steps for logging console logs to a file.
Good day, I have the same issue, i have USG1900 running on V4.33(AAPL.0) / 2019-01-09 09:38:28the latest firmware,what is the cause?0
Hi @nacho
Have you done anything before system reboot itself?
How often the symptom will happen again?
Can you go to collect diag-info and forward it to me by private message?
(Maintenance > Diagnostics > click “collect now” and wait for around 5 mins. And go to “Files” to download the file)
Zyxel_Stanley said:
Hi @nacho
Hi Stanley,Nothing was done before then. I gave sent you the files now0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
