Multy X 4 nodes with Ethernet Backhaul
MrShekel
I have a setup like this:
If I connect a gigabit network switch to my main multy and then connect a fourth Multy X via an ethernet cable, will it work? The important thing here is that I need everything to be on ethernet backhaul, as I have really really thick walls.
I've read this thread, but it doesn't answer my question:
https://homeforum.zyxel.com/discussion/1411/will-multi-handle-6-nodes
#MultyX_Dec_2019
#MultyX_Dec_2019
Best Answers
Dear @MrShekel,
Yes, you can connect two Multy via a switch.
Please note, you will have to pair them wirelessly first before you use the Ethernet backhaul.
You can refer to this KB,
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN
@Zyxel_Eric awesome, thank you! That actually answered more than question I had, including about the mini!
It would be awesome if that article would be somewhere more visible and easier to access, if possible
Dear @MrShekel,
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
