Any experience with loosing WAN after appx 24hrs ?
LuboL
Posts: 2 Freshman Member
Im have kind of bad luck or missing something badly, as between 24 and 48 hrs my Zyxel NBG 6615 basically says good bye to outside world, and I need either to restart it or hit 'Apply' button in Network>WAN>Internet Connection sub menu so it reconnects and again runs OK within mentioned time period.
Running it on newest firmware V1.00(ABMV.3)C0, no matter what settings, it always drops connection after that time. WAN led lights normally, in router status window I see my provider gateway (but I cannot tracert to it), logs are not helping at all, (there`s nothing much to see there)... Im already having replacement of same model so either I got 2 faulty routers or something is not working correctly between my ISP and this brand.
#Home_Router_Dec_2019
Years ago I had a router which lost internet access after exactly 6 or 12 hours, being half of the DHCP leasetime my ISP used. It's normal a DHCP client requests a prolongation when half of the time is over, and for some reason that caused my client to drop it's address.The problem was solved after a factory reset and reconfiguration.If your problem is not after appx 24 hours but exact 24 hours, I'd say you also have a DHCP problem.
@Hill
happened again basically after 24hrs, to my topology, optic fiber to Huawei GPON echoLife hg8240 (provided by ISP) splitting to TV and ethernet 1GB cable to Zyxel 6615 then directly ethernet 1GB to PC, and Wifi to mobile devices. WAN type DHCP client, I tried to mimic ISP setting from provided DLink router which ran without issues, but I also tried Zyxel keeping defaults...no matter what its still looses connectivity (today appx. after 24hrs since last renewal)0 -
@LuboL,
In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box. Thank you.
- 394 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 908 Nebula FAQ
- 415 Security FAQ
- 236 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 138 Service & License FAQ
- 73 About Community
- 62 Security Highlight
