Problem with NAS 310
r_kubis
r_kubis Posts: 1 image  Freshman Member
edited December 2019 in Personal Cloud Storage
Welcome.
I am asking you for help. The problem is that I can't connect to the NSA 310 via www. NAS Starter Utility can't see it. I have the IP address after scanning. After turning on the drive, the SYS indicator flashes and the HDD lights up after a while, it starts to beep every second.
If the wrong department please transfer.
After connection, RS-232 shows:
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** MARVELL BOARD: RD-88F6281A LE
U-Boot 1.1.4 (Feb 22 2011 - 10:31:35) Marvell version: 3.4.19
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006CFEE0
Soc: 88F6281 A1 (DDR2)
CPU running @ 1200Mhz L2 running @ 400Mhz
SysClock = 400Mhz , TClock = 200Mhz
DRAM CAS Latency = 5 tRP = 5 tRAS = 18 tRCD=6
DRAM CS[0] base 0x00000000 size 256MB
DRAM Total size 256MB 16bit width
Addresses 10M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (10M - 7M): Done
NAND:128 MB
Flash: 0 kB
CPU : Marvell Feroceon (Rev 1)
Kernel address is 0xc80000.
Streaming disabled
Write allocate disabled
Module 0 is RGMII
Module 1 is TDM
USB 0: host mode
PEX 0: PCI Express Root Complex Interface
PEX interface detected Link X1
Net: egiga0, egiga1 [PRIME]
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0xc80000, size 0xa00000
Reading data from 0x167f800 -- 100% complete.
10485760 bytes read: OK
## Booting image at 02000000 ...
Image Name: Linux-2.6.31.8
Created: 2016-03-11 9:35:37 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5696716 Bytes = 5.4 MB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................................................................................................................................................................................................................................ done, booting the kernel.
Linux version 2.6.31.8 (root@BuildMachine) (gcc version 4.3.2 (sdk3.3-ct-ng-1.4.1) ) #2 Fri Mar 11 17:35:20 CST 2016
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
CPU: VIVT data cache, VIVT instruction cache
Machine: Feroceon-KW
Using UBoot passing parameters structure
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 65024
Kernel command line: console=ttyS0,115200 mtdparts=nand_mtd:0x100000(uboot),0x80000(uboot_env),0x80000(key_store),0x80000(info),0xA00000(etc),0xA00000(kernel_1),0x2FC0000(rootfs1),0xA00000(kernel_2),0x2FC0000(rootfs2) root=/dev/nfs rw init=/init
PID hash table entries: 1024 (order: 10, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 244992KB available (5304K code, 300K data, 2804K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Console: colour dummy device 80x30
Calibrating delay loop... 1199.30 BogoMIPS (lpj=5996544)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Feroceon L2: Enabling L2
Feroceon L2: Cache support initialised.
CPU Interface
SDRAM_CS0 ....base 00000000, size 256MB
SDRAM_CS1 ....disable
SDRAM_CS2 ....disable
SDRAM_CS3 ....disable
PEX0_MEM ....base e0000000, size 128MB
PEX0_IO ....base f2000000, size 1MB
PEX1_MEM ....no such
PEX1_IO ....no such
INTER_REGS ....base f1000000, size 1MB
NFLASH_CS ....base fa000000, size 2MB
SPI_CS ....base f4000000, size 16MB
BOOT_ROM_CS ....no such
DEV_BOOTCS ....no such
CRYPT_ENG ....base f0000000, size 2MB
Marvell Development Board (LSP Version KW_LSP_5.1.3_patch18)-- RD-88F6281A Soc: 88F6281 A1 LE
Detected Tclk 200000000 and SysClk 400000000
Marvell USB EHCI Host controller #0: c8040740
PEX0 interface detected Link X1
pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:01.0: PME# disabled
PCI: bus0: Fast back to back transfers disabled
mvPexLocalBusNumSet: ERR. Invalid PEX interface 1
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
RTC has been updated!!!
rtc mv_rtc: rtc core: registered kw-rtc as rtc0
RTC registered
cpufreq: Init kirkwood cpufreq driver
XOR registered 4 channels
XOR 2nd invalidate WA enabled
mvCesaInit: sessions=640, queue=64, pSram=f0000000
Warning: TS unit is powered off.
gpio_dev = fd00000
LED_SET_CTL_IOC_NUM= 6702
High gpio polarity = 50
High gpio polarity = 70
Enable Interrupt
mv88f6281_wdt: Watchdog Timer timeout = 8 sec.
mv88f6281_wdt: HW Watchdog timeout = 15 sec.
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
fuse init (API version 7.12)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
SGI XFS Quota Management subsystem
msgmni has been set to 478
alg: No test for cipher_null (cipher_null-generic)
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
console [ttyS0] enabled
brd: module loaded
loop: module loaded
Integrated Sata device found
IRQ 21/mvSata: IRQF_DISABLED is not guaranteed on shared IRQs
Wake up disk0......
Wake up disk1......
scsi0 : Marvell SCSI to SATA adapter
scsi1 : Marvell SCSI to SATA adapter
scsi 0:0:0:0: Direct-Access Seagate ST1000DM003-1SB1 CC41 PQ: 0 ANSI: 5
EnablePowerSaving
PowerSavingTime = 15
sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 0:0:0:0: [sda] 0-byte physical blocks
sd 0:0:0:0: Attached scsi generic sg0 type 0
Loading Marvell Ethernet Driver:
o Cached descriptors in DRAM
o DRAM SW cache-coherency
o 0 Giga ports supported
o Single RX Queue support - ETH_DEF_RXQ=0
o Single TX Queue support - ETH_DEF_TXQ=0
o TCP segmentation offload (TSO) supported
o Large Receive offload (LRO) supported
o Receive checksum offload supported
o Transmit checksum offload supported
o Network Fast Processing (Routing) supported - (Disabled)
o Driver ERROR statistics enabled
o Proc tool API enabled
o SKB Reuse supported - (Disabled)
o SKB Recycle supported - (Disabled)
o Rx descripors: q0=128
o Tx descripors: q0=532
o Loading network interface(s):
mvFpRuleDb (c8d42000): 2048 entries, 8192 bytes
Counter=0, opIdx=6, overhead=16
Counter=1, opIdx=2, overhead=0
Counter=2, opIdx=1, overhead=18
Counter=3, opIdx=2, overhead=0
sd 0:0:0:0: [sda] Write Protect is off
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 690 at 0x000005640000
9 cmdlinepart partitions found on MTD device nand_mtd
Using command line partition definition
Creating 9 MTD partitions on "nand_mtd":
0x000000000000-0x000000100000 : "uboot"
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
0x000000100000-0x000000180000 : "uboot_env"
0x000000180000-0x000000200000 : "key_store"
sda:
0x000000200000-0x000000280000 : "info"
0x000000280000-0x000000c80000 : "etc"
0x000000c80000-0x000001680000 : "kernel_1"
0x000001680000-0x000004640000 : "rootfs1"
0x000004640000-0x000005040000 : "kernel_2"
0x000005040000-0x000008000000 : "rootfs2"
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_marvell ehci_marvell.70059: Marvell Orion EHCI
ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1
sda1
sd 0:0:0:0: [sda] Attached SCSI disk
ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
uhci_hcd: USB Universal Host Controller Interface driver
usbcore: registered new interface driver usblp
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
hwmon-vid: Unknown VRM version of your CPU
lm85 0-002e: Starting monitoring
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: mvsdio driver initialized, lacking card detect (fall back to polling)
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
Mobile IPv6
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
rtc mv_rtc: setting system clock to 2000-01-01 01:25:59 UTC (946689959)
Freeing init memory: 2804K
*** Stage 1: Setup system and device drivers ***
usb 1-1: new high speed USB device using ehci_marvell and address 2
In hub_port_init, and number is 0, retry 0, port 1 .....
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
r8168 Gigabit Ethernet driver 8.023.00-NAPI loaded
r8168 0000:00:01.0: no MSI. Back to INTx.
Set LED ...
eth%d: RTL8168B/8111B at 0xd0900000, 00:00:00:00:00:30, IRQ 9
r8168: This product is covered by one or more of the following patents: US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776, and US6,327,625.
r8168 Copyright (C) 2011 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
r8168: egiga0: link down
ADDRCONF(NETDEV_UP): egiga0: link is not ready
*** Stage 2: Prepare the root file system ***
Mount system partition...
yaffs: dev is 32505862 name is "mtdblock6" ro
yaffs: passed flags ""
lsFrownzyxel/mnt/nand/sysdisk.img.gz: No such file or directory
NAND Flash Corrupt...
Starting Pure-FTPd ...
/etc/init.d/rcS: line 212Frownbin/pure-ftpd.official: not found
1 second...
2 second...
r8168: egiga0: link up
ADDRCONF(NETDEV_CHANGE): egiga0: link becomes ready
3 second...
4 second...
5 second...
6 second...
7 second...
8 second...
9 second...
10 second...
sda
checking sda
Trying to mount /dev/sda1
mount: unknown filesystem type 'ntfs'
Fail to mount /dev/sda1
the sys-root image /dev/mtdblock6 is currupt !!
Dual images are currupt !!!
1 second...
2 second...
3 second...
4 second...
5 second...
6 second...
7 second...
8 second...
9 second...
10 second...
sda
checking sda
bz time = 1f
bz status = 3
start buzzer
Please press Enter to activate this console.
BusyBox v1.17.2 (2016-03-11 17:11:16 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
#NAS_Dec_2019
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    I see a combination of problems:
    For some reason the disk has a Windows filesystem, which it can't mount.
    The internal flash is corrupted, so a part of the firmware is lacking.
    It might help to reflash the firmware. You can use the 'force flash' script for that. The downloads mentioned on that page can be found here and here.
