FTP einloggen geht nicht mehr Java fehler Auth fehler
2»
  • Mijzelf
    Mijzelf Posts: 3,030 image  Guru Member
    Strange. A fritzbox usually has good firmware. What if you disable the internal ftp server in the fritzbox?
  • catweazle
    catweazle Posts: 8 image  Freshman Member
    same Thing. i do a reset of the NAS 540. still the same result.
  • Mijzelf
    I advice you to contact AVM about this issue.
