Nas326 java install for jdownloader
Ustach
Ustach Posts: 6 image  Freshman Member
edited December 2019 in Personal Cloud Storage
Hi
I tried to install java on my nas326 but no success. I need it to install jdownloader for premium downloads.
I know there is pyload but it can't unrar files with few parts.
Jdownloader have good archive extractor and simple remote controller from any internet connection.
I try this tutorial
https://nas-tweaks.net/419/installation-of-java-on-the-nas-under-fun_plug/
But when i'm on step with echo command nothing happen.
Please help me. I bought zyxel only for jdownloader and i cant run it.
Regards
#NAS_Dec_2019
  • Mijzelf
    Mijzelf Posts: 2,990 image  Guru Member
    That command is not supposed to give any output on success. So just go on with the chmod.
  • Ustach
    I did this. And logout. When i login and put java -version. There is no java
    edit.
    I just read on this tutorial that i need to to install fun plug first. Correct me if im wrong.
    I'll do this.
    edit. 2
    Maybe someone know easier way to jdownloader / java install ?
    Fun Plug is hard for me
  • Mijzelf
    Basically the installation is extracting the tarball somewhere, and add 'somewhere' to the PATH. fun_plug (or better ffp) is only used as an environment to change that PATH variable. If that is too difficult, how do you want to install jdownloader?
  • Ustach
    When i got java j will try this https://support.jdownloader.org/Knowledgebase/Article/View/52/13/install-jdownloader-on-nas-and-embedded-devices tutorial. There is zyxel nas support so i buy zyxel. I didnt know there i so many problems with java.
    Can someone help me what i have to do to have jdownloader? Step by step. Please
  • Ustach
    ok
    i already install ppf and metarepo on my nas326. now i trying install java with tutorial in first link. all commands are without errors and i logout. when login and type java -version i have no command found.
    any idea ?
  • Mijzelf
    What is the output of
    echo $PATH
  • Ustach
    Connecting to 192.168.0.196 port 22, please wait...
    login as:
    root@192.168.0.196's password:
    == Welcome at FFP version 0.7/arm, running on Unknown-B303 NAS326, firmware V5.21(AAZF.5) ==
    echo $PATH
    /ffp/opt/java/jre/linux_arm_sflt/jre/bin:/ffp/opt/java/jre/linux_arm_sflt/jre/bin:/ffp/opt/java/jre/bin:/ffp/sbin:/usr/sbin:/sbin:/ffp/bin:/usr/bin:/bin
    root@NAS326:~#
  • Mijzelf
    And what is the output of
    ls -l /ffp/opt/java/jre/linux_arm_sflt/jre/bin/
    ls -l /ffp/opt/java/jre/bin/
  • Ustach
    login as:
    ls: cannot access /ffp/opt/java/jre/linux_arm_sflt/jre/bin/: No such file or directory
    root@NAS326:~# ls -l /ffp/opt/java/jre/bin/
    ls: cannot access /ffp/opt/java/jre/bin/: No such file or directory
    root@NAS326:~#
  • Mijzelf
    Those directories clearly do not exist. When you followed the instructions on nas-tweaks to the letter, I guess you have a newer version of jre than 1.7.0_06, which makes the symlink fail. So find out to which directory the tarball extracted, and re-create the symlink.
