Beeping Zyxel 326
Nowhere
My Zyxel 326 had started beeping at me about once a minute or so. Support said they're is something wrong with the drives. I tested them and they are fine I even put in two other drives and it still beeps at me. I've even tried it without any drives and I still get the beeping and I can't access the nas via windows. Any ideas?
#NAS_Jan_2020
#NAS_Jan_2020
I followed these instructions from support. Pulled out both drives, disconnected power, disconnected the cat 5 cable. Hit the reset button till it beeped twice, put everything back in place and now it works fine and both drives show as healthy.
I tested them and they are fineHow do you test them?
Do you check "Hard Disk > DiskX > S.M.A.R.T > Overview/S.M.A.R.T Info"?
What is the result? Shows disk as Good or Bad?
If you pull out all disks, is NAS326 still beeping? And do you able to access web interface of NAS326 at the moment?
I checked them using Seatools and they show good. Pulling both drives it still beeps. I am not able to access the web interface currently.
Forum user Mijzelf has collected some recovery sticks.
http://zyxel.diskstation.eu/Users/Mijzelf/RescueSticks/
Please try, unzip the right one to the USB stick, put it in a back port, and reboot the NAS.
Hope it can help you.
- 588 USG FLEX H Series
- 476 News and Release
