VMG3925 and DFS
Anonymous
When I try to scan wireless channels with my VMG3925 it gives the following warning/error:
"Channel scan process is denied because current channel is a DFS channel (Channel: 52~140). If you want to run channel scan, please select a non-DFS channel and try again."
I'm using 2.4 GHz Wifi with channel "auto" or 1 and 5.0 Ghz's channel is 36. Although 5.0 GHz Wifi is turned off, since I'm using just 2.4 GHz. The reason I'm trying to use scan to see less occupied channels is because VMG3925 drops Wlan several times in a hour (+10). The actual internet connection is working fine with direct connection, so there's some malfunction with Wlan (and yes I have read the forums about this common problem with no solution for it, besides tossing Zyxel product in to a trash bin).
How I can select non-DFS channel, which I already have done, to make scan work? Or am I missing something here.
#SP_Feb_2020
#SP_Feb_2020
Hello,I assume you disable 5GHz and then go to Channel Status page to scan directly without changing the page back to 2.4GHz in General page.Try following steps:
- Log in GUI
- Go to Network Setting > Wireless > General from the Menu
- Make sure 2.4GHZ is the current used band shown on the General page (If not, please select 2.4G and click Apply button without modifying any settings.)
- Switch to Channel Status page (Network Setting > Wireless > Channel Status) and click the Scan button to scan
Do you know which firmware version you are using?0 -
Latest firmware (V5.13/AAVF.13). It doesn't make a difference if I choose 2.4 Ghz as current band with shown. Still gives the warning.0
I tried it with the same firmware version but it's no problem in my test.I didn't meet your problem.How about try to reset your device to default settings and then try it again?0
- Log in GUI
- Switch to Channel Status page (Network Setting > Wireless > Channel Status) and click the Scan button to scan MyFedLoan Servicing
Very informative and useful post for me!
Hummel said:Hello,I assume you disable 5GHz and then go to Channel Status page to scan directly without changing the page back to 2.4GHz in General page.Try following steps:
- Log in GUI
Do you know which firmware version you are using? Tellthebell-1 -
Anonymous said:When I try to scan wireless channels with my VMG3925 it gives the following warning/error:
#SP_Feb_2020Not much help to you at the moment but I can attest that Articulate are working on this.
-1 -
Current firmware version (V5.13/AAVF.13). If I set the current band to 2.4 Ghz, it makes no difference. The caution remains. MyFedLoanAnonymous said:When I try to scan wireless channels with my VMG3925 it gives the following warning/error:
#SP_Feb_2020
-1 -
Nice Post,
Thanks for sharing this useful information with us
-1 -
I tried it with the same firmware version and haven't find any problemWhy please try one more time-1 -
Using the official MyFedLoan website, you can access many services that will make managing federal student loans more manageable. The Myfedloans Login portal offers an easy-to-navigate interface that is responsive and helps in customer support.
-1
- 441 Beta Program
- 292 Service & License
