NAS540 cant install apps
Sir_Mc_Tod
Sir_Mc_Tod Posts: 20  Freshman Member
edited February 2020 in Personal Cloud Storage
i recently had a broken harddisk (not for the first time) so i took the nas out of business for a few days until replacement arrived, and replaced the broken disk, all went fine (except for the lack of speed doing the resync, but one gets used to it)
When the arrays where in sync again i wanted to connect to my nfs shares, my ownCloud instance and the database but none of which worked. so i went to the app center to see whats going on, and all of my installed apps showed "unknown error", so i tried uninstalling nfs (since its quite easy to configure again afterwards) and reinstalling it but every time i try installing it says "unknown error" again. (tried a few other apps as well, always the same)
Can anyone tell me whats wrong an give hints to get things going again?
otherwise i will have to look into getting debian with openmediavault to work on it to bypass the factory software  (at least i would know where to look then when something goes wrong)
#NAS_Feb_2020
«1
  • Mel
    Mel Posts: 83  Ally Member
    What's happen after you clicked "Retrieve List From Internet"?
    If it is success, please try to uninstall/install APPs again.
  • Sir_Mc_Tod
    damn now my web frontend broke away, rebooted, got login screen, put credentials in, wait... gone again. ok got it back on one interface, the second network interface is down.
    cant access anything because i hav to go to the storage menu first (disk has fallen out of array again) which doesnt load.
    i think that box has some serious issues
  • Sir_Mc_Tod
    got to that menu, you were talking about and hit the button, it failed.
    but it does have internet connection i can ping for example google.com from the commandline
  • Sir_Mc_Tod
    ok, got the second interface back, and frontend seems to be working as well again.
    can ping any domain successfully form the commandline and the ping tool in the frontend is successfull as well, but i can not refresh the app list
  • Sir_Mc_Tod
    Hmm i removed the ZYPKGS file like described here:  https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015051&lang=EN### now my list (installed as well as all)  is completely empty (even after putting the file back, as I just moved it)  but it still doesn't refresh. But the phpmyadmin link reappeared on my dashboard (doesn't point anywhere...)
  • Sir_Mc_Tod
    cat /i-data/.system/zy-pkgs/tmp/zypkg.log
    2020-02-05 16:48:37 [ipkg][][21908]: System Volume exist, SysVolPath = /i-data/5c72062c/.system, return 1
    2020-02-05 16:48:37 [ipkg][][21908]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp download DefaultWebSite ZYPKG_INFO.tgz"
    2020-02-05 16:48:37 [ipkg][download][21908]: [ipkg_op][566] cmd_name: download, argv[6]: DefaultWebSite
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_set_web_site][2111] ---> using "/i-data/sysvol/admin/zy-pkgs/web_prefix"
    2020-02-05 16:48:37 [ipkg][download][21908]: full_ptr_path = ftp://ftp2.zyxel.com/NAS540/zypkg/5.21
    2020-02-05 16:48:37 [ipkg][download][21908]: ZYPKG_DEFAULT_WEB_PREFIX = ftp://ftp2.zyxel.com
    2020-02-05 16:48:37 [ipkg][download][21908]: ptr_path = NAS540/zypkg/5.21
    2020-02-05 16:48:37 [ipkg][download][21908]: strWebPrefix =http://localhost:59999, strWebPath = NAS540/zypkg/5.21
    2020-02-05 16:48:37 [ipkg][download][21908]: strEncodedURL = http://localhost:59999, strEncodedModelName = NAS540/zypkg/5.21
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_set_web_site][2170] web site: "http://localhost:59999/NAS540/zypkg/5.21@
    2020-02-05 16:48:37 [ipkg][download][21908]: start [zypkg_download] with [http://localhost:59999/NAS540/zypkg/5.21]-[ZYPKG_INFO.tgz]-[/tmp/ZYPKG_INFO.tgz]-[zypkglist]
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download][327] resumeFrom: "0".
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download] strDownloadFile: http://localhost:59999/NAS540/zypkg/5.21/ZYPKG_INFO.tgz
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download][391] do "cbCurlHeaderFunc".
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download] Start to download zypkglist
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download] ********* curl_result: 7
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download] ********* [??] curl_result: 7
    2020-02-05 16:48:37 [ipkg][download][21908]: [zypkg_download] Download zypkglist TIMEOUT
    2020-02-05 16:48:37 [ipkg][download][21908]: [ipkg_op][652] download result: 7
    2020-02-05 16:48:38 [ipkg][][21918]: System Volume exist, SysVolPath = /i-data/5c72062c/.system, return 1
    2020-02-05 16:48:38 [ipkg][][21918]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp list"
    2020-02-05 16:48:38 [ipkg][list][21918]: [ipkg_op][807]cmd_name = list, argv[optind] = (null)
    2020-02-05 16:48:38 [ipkg][list][21918]: ********* [zypkg_list_zypkg_contents][1406][PHP-MySQL-phpMyAdmin] missing description of package "PHP-MySQL-phpMyAdmin", maybe it's just installed but not included in package list? We'll skip it. *********
    2020-02-05 16:48:38 [ipkg][list][21918]: ********* [zypkg_list_zypkg_contents][1406][ownCloud] missing description of package "ownCloud", maybe it's just installed but not included in package list? We'll skip it. *********
    2020-02-05 16:48:40 [ipkg][][21928]: System Volume exist, SysVolPath = /i-data/5c72062c/.system, return 1
    2020-02-05 16:48:40 [ipkg][][21928]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp list"
    2020-02-05 16:48:40 [ipkg][list][21928]: [ipkg_op][807]cmd_name = list, argv[optind] = (null)
    2020-02-05 16:48:40 [ipkg][list][21928]: ********* [zypkg_list_zypkg_contents][1406][PHP-MySQL-phpMyAdmin] missing description of package "PHP-MySQL-phpMyAdmin", maybe it's just installed but not included in package list? We'll skip it. *********
    2020-02-05 16:48:40 [ipkg][list][21928]: ********* [zypkg_list_zypkg_contents][1406][ownCloud] missing description of package "ownCloud", maybe it's just installed but not included in package list? We'll skip it. *********
    Curl error 7 means permission denied,  as that's a request to localhost at port 59999 that doesn't make any sense at all.
    1.The box its blocking a request to itself
    2. Why does it look for a packaglist on localhost?
  • Mijzelf
    Mijzelf Posts: 2,930  Guru Member
    You have MetaRepository installed and active.
  • Sir_Mc_Tod
    We'll it was installed,  that's true,  but I don't know how it works internally,  and it wasn't active anymore.  How do I fix it?
  • Sir_Mc_Tod
    OK,  thanks for the hint,  I removed the web prefix and got a available apps list.  But my apps are still marked with "unknown error" that doesn't change when uninstalling and re-installing
  • Sir_Mc_Tod
    2020-02-05 18:16:18 [ipkg][][31796]: System Volume exist, SysVolPath = /i-data/5c72062c/.system, return 1
    2020-02-05 18:16:18 [ipkg][][31796]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp download DefaultWebSite ZYPKG_INFO.tgz"
    2020-02-05 18:16:18 [ipkg][download][31796]: [ipkg_op][566] cmd_name: download, argv[6]: DefaultWebSite
    2020-02-05 18:16:18 [ipkg][download][31796]: [zypkg_set_web_site][2127] ---> using "/etc/package_src_url" (for white box version)
    2020-02-05 18:16:18 [ipkg][download][31796]: [zypkg_set_web_site][2141] web site: "ftp://ftp2.zyxel.com/NAS540/zypkg/5.21"
    2020-02-05 18:16:18 [ipkg][download][31796]: [ipkg_op][616] @@@ strURL: DefaultWebSite @@@
    2020-02-05 18:16:18 [ipkg][download][31796]: start [zypkg_download] with [ftp://ftp2.zyxel.com/NAS540/zypkg/5.21]-[ZYPKG_INFO.tgz]-[/tmp/ZYPKG_INFO.tgz]-[zypkglist]
    2020-02-05 18:16:18 [ipkg][download][31796]: [zypkg_download][327] resumeFrom: "0".
    2020-02-05 18:16:18 [ipkg][download][31796]: [zypkg_download] strDownloadFile: ftp://ftp2.zyxel.com/NAS540/zypkg/5.21/ZYPKG_INFO.tgz
    2020-02-05 18:16:18 [ipkg][download][31796]: [zypkg_download] Start to download zypkglist
    2020-02-05 18:16:25 [ipkg][download][31796]: [zypkg_download] ********* curl_result: 0
    2020-02-05 18:16:25 [ipkg][download][31796]: [zypkg_download] ********* [OK] curl_result: 0
    2020-02-05 18:16:25 [ipkg][download][31796]: [zypkg_download][462] Downloading "ftp://ftp2.zyxel.com/NAS540/zypkg/5.21/ZYPKG_INFO.tgz" success
    2020-02-05 18:16:25 [ipkg][download][31796]: finish [zypkg_download] with return value (0)
    2020-02-05 18:16:25 [ipkg][download][31796]: [zypkg_extract_dl_file][2217] strCmd: "/bin/tar -zxf /tmp/ZYPKG_INFO.tgz -C /"
    2020-02-05 18:16:25 [ipkg][download][31796]: [ipkg_op][652] download result: 0
    2020-02-05 18:16:26 [ipkg][][31845]: System Volume exist, SysVolPath = /i-data/5c72062c/.system, return 1
    2020-02-05 18:16:26 [ipkg][][31845]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp list"
    2020-02-05 18:16:26 [ipkg][list][31845]: [ipkg_op][807]cmd_name = list, argv[optind] = (null)
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][AuroraSyncBackup] start listing package "AuroraSyncBackup" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_installed_pkg_info][2420] open "" failed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][AuroraSyncBackup] No Installed version, conf version: 0.0.1zypkg002
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][AuroraSyncBackup] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_pkg_insttime][1236]TimePkgInstRule = (null)
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][DropboxClient] start listing package "DropboxClient" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][DropboxClient] No Installed version, conf version: 6.7.0zypkg002
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][DropboxClient] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][GoogleDriveClient] start listing package "GoogleDriveClient" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][GoogleDriveClient] No Installed version, conf version: 0.5.0zypkg006
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][GoogleDriveClient] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][Memopal] start listing package "Memopal" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][Memopal] No Installed version, conf version: 3.0.0zypkg005
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][Memopal] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][NFS] start listing package "NFS" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][NFS] No Installed version, conf version: 1.3.0zypkg007
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][NFS] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][NZBGet] start listing package "NZBGet" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][NZBGet] No Installed version, conf version: 15.0zypkg005
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][NZBGet] status: Not Installed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][NZBGet] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][PHP-MySQL-phpMyAdmin] start listing package "PHP-MySQL-phpMyAdmin" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_installed_pkg_info][2408][PHP-MySQL-phpMyAdmin]strControlFile = /i-data/5c72062c/.PKG/PHP-MySQL-phpMyAdmin/zypkg_conf/info/PHP-MySQL-phpMyAdmin.control
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_installed_pkg_info][2411] "PHP-MySQL-phpMyAdmin" control file does not exist.
    2020-02-05 18:16:26 [ipkg][list][31845]: ===> [zypkg_set_pkg_unknown_status][925] Set unknown status for package "PHP-MySQL-phpMyAdmin"
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_set_pkg_unknown_status][929] strCmd: touch "/i-data/.system/zy-pkgs/tmp/PHP-MySQL-phpMyAdmin.unknown"
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][PHP-MySQL-phpMyAdmin] No Installed version, conf version: 1.0zypkg007
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][PHP-MySQL-phpMyAdmin] status: Unknown
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][PHP-MySQL-phpMyAdmin] btn: "inst uninst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_pkg_insttime][1236]TimePkgInstRule = /i-data/5c72062c/.PKG/PHP-MySQL-phpMyAdmin/
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][SqueezeCenter] start listing package "SqueezeCenter" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][SqueezeCenter] No Installed version, conf version: 7.7.4zypkg007
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][SqueezeCenter] status: Not Installed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][SqueezeCenter] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][Tftp] start listing package "Tftp" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][Tftp] No Installed version, conf version: 0.7zypkg006
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][Tftp] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][Transmission] start listing package "Transmission" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][Transmission] No Installed version, conf version: 2.84zypkg005
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][Transmission] status: Not Installed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][Transmission] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][WordPress] start listing package "WordPress" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][WordPress] No Installed version, conf version: 4.4.1zypkg005
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][WordPress] status: Not Installed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][WordPress] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][gallery] start listing package "gallery" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][gallery] No Installed version, conf version: 3.0.9zypkg005
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][gallery] status: Not Installed
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][gallery] btn: "inst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][myZyXELcloud-Agent] start listing package "myZyXELcloud-Agent" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][myZyXELcloud-Agent] No Installed version, conf version: 1.0.5zypkg0105
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][myZyXELcloud-Agent] status: Unknown
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1624][myZyXELcloud-Agent] btn: "inst uninst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][ownCloud] start listing package "ownCloud" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_installed_pkg_info][2408][ownCloud]strControlFile = /i-data/5c72062c/.PKG/ownCloud/zypkg_conf/info/ownCloud.control
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_installed_pkg_info][2411] "ownCloud" control file does not exist.
    2020-02-05 18:16:26 [ipkg][list][31845]: ===> [zypkg_set_pkg_unknown_status][925] Set unknown status for package "ownCloud"
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_set_pkg_unknown_status][929] strCmd: touch "/i-data/.system/zy-pkgs/tmp/ownCloud.unknown"
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][ownCloud] No Installed version, conf version: 7.0.15zypkg006
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1472][ownCloud] status: Unknown
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][ownCloud] btn: "inst uninst info", IsNewVerExist: 0
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_get_pkg_insttime][1236]TimePkgInstRule = /i-data/5c72062c/.PKG/ownCloud/
    2020-02-05 18:16:26 [ipkg][list][31845]: ********* [zypkg_list_zypkg_contents][1416][pyLoad] start listing package "pyLoad" *********
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1428][pyLoad] No Installed version, conf version: 0.4.9zypkg007
    2020-02-05 18:16:26 [ipkg][list][31845]: [zypkg_list_zypkg_contents][1629][pyLoad] btn: "inst info", IsNewVerExist: 0
