USG 110 - clear port statistics
AWUSupport
Does anyone know the CLI command to clear port statistics - in our case Ethernet Port5?
I think it along the lines of interface reset however cannot get the correct syntax.
@AWUSupport
The Port statistics can not be reset or clean via CLI, however, the statistics can be reset after you plug network cable out and plug it in.
Charlie0 -
Charlie,
Can you review this snip from a CLI Reference Guide - seems to suggest it can be done however I am uncertain as to correct syntax.
@AWUSupport
It seems there is miscommunication:). Initial request is "clear port statistics ", so I informed you need to plug network cable out-in.
(physical Port and Interface are different. One port can be separated to numbers of interface )Yes, we can do rest interface via CLI. Please check as below.
Enter "show interface summary all status" to check all interface status, and enter "interface reset wan1" to reset wan1 interface.
Charlie
That is true, clear port statistics is what we were after however we were hoping if all interfaces were cleared then maybe this would clears the port used by those interfaces. Seems our hopes were in vain. Thanks for your help.0
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
