PLEX on NAS542
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Some text has disappeared on that page for some reason. The text which should be there is
    Install
    Due to licensing and hosting problems this package does not contain the Plex Media Server itself, only an installer- and start script.
    1 Download
    Your box runs an ARMv7 processor. You can download the package for Synology ARMv7 here.
    2 Upload
    3 Install
    So the idea is that you download a Synology Armv7 package to your PC, upload it to the NAS542, and install it.
  • Plex on NAS542
    Plex on NAS542 Posts: 19 image  Freshman Member
    Hi!!!
    Is the package os Synology Armv7 compatible with our Zyxel NAS? From where we can download it?
    Thanks!!!!
  • Mijzelf
    Sort of. The binary runs on the processor, and the PlexMediaServer zypkg creates a fake Synology environment for it.
    The 'here'  on your webpage is a hyperlink.
  • Plex on NAS542
    In the link of the "here" of my divice, I link here (https://www.plex.tv/media-server-downloads/). Can I find the package os Synology ArmV7 in this link?
  • Plex on NAS542
    Yes. I found it. Thanks. I Will try the install.
  • Plex on NAS542
    I try with this 2 files with the upload option but the NAS don´t install nothing. What I´m doing bad?
  • Plex on NAS542
    Sorry, the picture don´t upload.
    I download this 2 files of Synology but the NAS don´t do it nothing after UPLOAD the files. Are not this files?
  • Mijzelf
    As far as I can see both files should be sufficient. The 'neon' version is supposed to run slightly smoother, but I doubt you will feel the difference.
    As the page shows distorted, some text is missing in '1 Download', I'd try a different browser.
  • Plex on NAS542
    Thanks a lot!!!!
    With Chrome don´t have problem for install.
    Regards.
  • Plex on NAS542
    Sorry for come back again with another problem with the Plex. I install and create a account, all without problem. The Plex detect the NAS but when I want create a folder with for share the media with the TV, I can´t set the folders of the Video, for example, of the NAS. I only have this folder option that really is not ready in the NAS (see picture);
    How I could set the folders in this screen?
    Thanks.
