How to configure Samba share to sort alphabetically?
Nickba
Nickba Posts: 17 image  Freshman Member
edited January 2020 in Personal Cloud Storage
I have a NAS326 and I have some devices that cannot sort alphabetically on clients end. I need to configure need the NAS326 to sort alphabetically. I tried to edit the smb.conf, but it didn’t work.
#NAS_Jan_2020
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    AFAIK Samba doesn't do any sorting at all. That is left to the client.
    What did you try to change in smb.conf?
  • Nickba
    Thanks for replying. I have a Synology NAS and it does have an option to sort alphabetically.
    I put this in the smb.conf:
    vfs objects = dirsort
    Does anyone have any tip to make it work?
  • Mijzelf
    OK. A vfs module is a sort of plugin. In this case the module is part of the samba suite. The NAS might have a stripped down version which doesn't contain this plugin. Don't know if that is possible.
    How did you test the smb.conf change? Did you restart samba after that?
    /etc/init.d/samba.sh restart
    An other option is to sort the files on the NAS itself. This is only feasible on mainly static shares, as new files aren't added alphabetically.
    Sorting is easy:
    su
    cd /path/to/share
    mkdir tmpsort
    mv * tmpsort/
    mv tmpsort/* .
    rmdir tmpsort
    Note the dot at the end of the 2nd mv. The theory here is that the shell will exchange the * by an (alphabetically sorted) list of filenames, and mv will move them in that sequence. As the move is within the same filesystem, it's only administative, and blazing fast.
  • Nickba
    Hello Mijzelf,
    Thanks again for replying.
    Yes, I did restart samba after I changed the smb.conf and it didn't work.
    I tried your suggested static solution, it moved the the files ok, but when I tested on the network, the files didn't sort alphabetically. Maybe samba pick the files randomly to show the list if  vfs objects = dirsort cannot be used.
    Do you know if there is a way to configure the NFS plugin app to sort alphabetically? I am asking because the clients also support NFS.
  • Nickba
    edited February 2020
    Hello again,
    I installed OMV on an old PC and it accepts the option vfs objects = dirsort and works perfectly.
    Do you know a simple method of installing OMV on the NAS326?
  • Mijzelf
    OMV runs on top of Debian. So https://forum.doozan.com/read.php?2,88619
