Is it possible to use NSA325v2 as VPN server?
Is it possible that the file hamcore.se2 is damaged? When I compare the logs of your chrooted execution with this one, it seems to crash on reading that file:open("/home/vpnserver/hamcore.se2", O_RDONLY|O_LARGEFILE) = 8
read(8, "HamCore"..., 7) = 7
read(8, "\0\0\0'"..., 4) = 4
<snip>
read(8, "\0\0\0&"..., 4) = 4
read(8, "\0\23\230\7"..., 4) = 4
open("/home/vpnserver/hamcore/languages.txt", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
_llseek(8, 4487, [4487], SEEK_SET) = 0
read(8, "x\234MP_K\302P\24\177n\260\357p\300\227\202KmS\253\327\20\203BD\214\3127\271\314\353\356"..., 346) = 346
open("/home/vpnserver/lang.config", O_RDONLY|O_LARGEFILE) = 9
open("/e-data/e9902f35-4024-4b41-9626-08c2131c7087/vpnserver/hamcore.se2",O_RDONLY|O_LARGEFILE) = 8
read(8, "HamCore", 7) = 7
read(8, "\0\0\0'", 4) = 4
<snip>
read(8, "\0\0\0&", 4) = 4
read(8, "\0\23\230\7", 4) = 4
open("/e-data/e9902f35-4024-4b41-9626-08c2131c7087/vpnserver/hamcore/languages.txt",O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
read(8, "x\234MP_K\302P\24\177n\260\357p\300\227\202KmS\253\327\20\203BD\214\3127\271\314\353"..., 346) = 346
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV (core dumped) +++0 -
Thank god I made a backup of that folder :-D
One additional question: right now I have those files on an external USB stick. If I were to copy all of those files to the /ffp/ folder, how much disk space would I have? Or is all this stored on the internal hdd?0 -
I don't understand the question. You know how much space is occupied on that USB stick, and you know how much disk space is left. How could I say what the effect of copying that file would be?
No, I meant: is there an internal memory in tha NAS apart from my HDDs where I could store the vpnserver?
If it's on the USB stick, the program will stop working as soon as the USB stick starts acting up. If I copy it to the ffp folder, it will be stored on the primary HDD and will keep my HDD alive even though I am not using it (tmp files etc.).
USB sticks are always error prone. They are cheap, but they are not reliable.0 -
Ah, I see.Well, the box has an internal flash partition where the config is stored. It's not big, something like 4MB, and I wouldn't store a significant amount of data there. And especially no logs, or other volatile data. If the flash wears out you can bin your NAS.In your case you could copy everything to a ramdrive, before starting it. The box has 512MB ram, and in most cases it doesn't use half of it. Don't know how big the package is? 8MB?0
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 290 Service & License
- 4.6K FAQ
