I have two PLA6456 and they worked fine but I have pixelation on my UVERSE SAMSUNG TV screen that ar
DAVIDL
I had AT&T send me a new U VERSE control box and it helped some but I still have the issue. When I unplugged the PLA6456's the TV cleared up. The PLA6456 were being used to extend my Ethernet for a PC in the same room that use the TV as a large monitor.
#PLA_Feb_2020
#PLA_Feb_2020
I have two PLA6456 and they worked fine but I have pixelation on my UVERSE SAMSUNG TV screen. This started after I strted using the PLA6456.
What is the firmware version of your PLA6456?
ftp://ftp2.zyxel.com/PLA6456/firmware/
The latest version is V1.00(ABSU.4)C0.0 -
1. What is your network topology? How do you connect those two PLA6456 and the TV?
2. Does the pixelation on TV only happen when the PC is streaming a viedo or all the time?
3. Do you run the Speedtest on your PC, and how is the result?
4. How does your PC access the internet after you unplugged the PLA6456 and your TV cleared up?
5. What is the color in the middle of the LED on PLA6456? green, amber, or red?
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
