OwnCloud 10 on Zyxel NAS
philippg
Hi, im wondering if it is possible to manually install a newer OwnCloud version on the Zyxel540 Nas system. I got the newest firmware but im not able to install the newest version of OwnCloud. So can I install the package via Putty (ssh)?
#NAS_Dec_2019
#NAS_Dec_2019
2
No answer from Zyxel. They are not care about customers.
Porfavor, serían tan amables de responder. Yo también estoy interesado.
Gracias0 -
Did you find a way? I just picked up an older Zyxel system. Nice box, but I prefer to run the latest owncloud. Any thoughts?0
You always need a software compiled for CPU contained in your NAS. Therefore you can't just take a file from another Linux distribution and put it into your NAS.0
Thank you. I do understand that software needs to be compiled for a specific CPU or at least architecture. I am confident that the Marvell SOC in here could run the latest owncloud, but I do not know how to compile for it and I had hoped someone in the community had done that. I understand that Zyxel will no longer provide updates to this, as it is EOL. However, sometimes there are strong technical people in a forum or community like this that have been able to do this type of work. Not that I expect it. Only that I ask if anyone had. I would love to run the latest owncloud! Thanks.0
The problem is not Owncloud itself, which is AFAIK 'just' a PHP script. But it needs a minimum version of PHP, which needs a minimum version of Apache, and it needs minimum version of MySQL or MariaDB, which all is not available on that NAS.If you are able and willing to do some configuration and installing, it should be able to install Owncloud on top of Entware.0
Thank you. I will look in to that. I appreciate the detailed explanation!0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
