web server configuration in zyxel cloud(NAS 326)
emau74
why do i find this error?
#NAS_Feb_2020
#NAS_Feb_2020
I'm this
It seems that there is port conflict.
May I know what is the purpose of this configuration?
If you want to access your NAS326 from outside, I will suggest you to add port forward on your router.
yes the purpose is to access the nas from the outside.on the router I set the door opening like this
After did this setting, do you able to access your NAS326 from outside?
You also can refer to this discussion.
https://homeforum.zyxel.com/discussion/comment/8053#Comment_8053I don't configure UPnP, only set port forward rules on my router.
- Paired my NAS on myZyxelCloud and set DDNS
- Port forward [external port <-> internal port] as 8483 <-> 4431 -
a few days ago I connected to my modem via lan Tenda Nova MW3 (wifi mesh).today by enabling the port on the nas in the UPnP port mapping, even on zyxel cloud it did not give me errors, however I still cannot connect from the outside.
68/5000if i open https://host_name.zyxel.me
the modem page appears
Try to add port number after URL, "https://host_name.zyxel.me:port_number".
I have already tried, if I put: 80 the modem login page opens, if I put: 5000 or 5001 "Could not reach the site" error
Please try to enable HTTPS on your NAS326.
Then, add a port forward rule [external port <-> internal port] as 8483 <-> 443.
After that, using URL to access your NAS326 from out side, for example - "https://abc123.zyxel.me:8483".
- 234 Nebula Ideas
- 6.7K Security
- 695 USG FLEX H Series
- 366 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 510 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 114 Security Highlight
