web server configuration in zyxel cloud(NAS 326)
emau74
emau74 Posts: 53
Friend Collector Third Anniversary
image  Ally Member
edited February 2020 in Personal Cloud Storage
why do i find this error?
#NAS_Feb_2020
  • emau74
    emau74 Posts: 53
    image  Ally Member
    I'm this
  • lodiabai
    lodiabai Posts: 120 image  Ally Member
    It seems that there is port conflict.
    May I know what is the purpose of this configuration?
    If you want to access your NAS326 from outside, I will suggest you to add port forward on your router.
  • emau74
    emau74 Posts: 53
    image  Ally Member
    yes the purpose is to access the nas from the outside.
    on the router I set the door opening like this
  • lodiabai
    After did this setting, do you able to access your NAS326 from outside?
    You also can refer to this discussion.
    https://homeforum.zyxel.com/discussion/comment/8053#Comment_8053
    I don't configure UPnP, only set port forward rules on my router.
    - Paired my NAS on myZyxelCloud and set DDNS
    - Port forward [external port <-> internal port] as 8483 <-> 443
  • emau74
    emau74 Posts: 53
    image  Ally Member
    a few days ago I connected to my modem via lan Tenda Nova MW3 (wifi mesh).
    today by enabling the port on the nas in the UPnP port mapping, even on zyxel cloud it did not give me errors, however I still cannot connect from the outside.
    68/5000
    if i open https://host_name.zyxel.me
    the modem page appears
  • Dash
    Dash Posts: 65 image  Ally Member
    Try to add port number after URL, "https://host_name.zyxel.me:port_number".
  • emau74
    emau74 Posts: 53
    image  Ally Member
    I have already tried, if I put: 80 the modem login page opens, if I put: 5000 or 5001 "Could not reach the site" error
  • Dash
    edited March 2020
    Please try to enable HTTPS on your NAS326.
    Then, add a port forward rule [external port <-> internal port] as 8483 <-> 443.
    After that, using URL to access your NAS326 from out side, for example - "https://abc123.zyxel.me:8483".
