amg1302-t10c as a wireless adapter
cfcc2020
I wanted to use the amg1302-t10c router as a wireless adapter (i.e. PC to this
router via ethernet cable, then this router to main router via wireless
connection) to boost internet speed of the PC. I searched everywhere and
could not find anything except to flash dd wrt into it, but this model
is not supported. I found the manual for the amg1302-t11c, but nothing
there either. Any ideas on how I can achieve this seemly simple task?
Tried setting it up as a bridge, but that didn't work either. Any help will
be much appreciated. Thank you.
Thank you. Is there any way of confirming this? Thanks again
Hi @cfcc2020AMG1302-T10C is designed to be used as a router or a gateway.
It doesn't support the feature to be a wireless repeater.
We suggest to connect the WAN port of AMG1302-T10C to your main router with an Ethernet cable according to your description.0
- 588 USG FLEX H Series
- 477 News and Release
