EMG3425 Port Fowarding Help
NClack
NClack Posts: 2 image  Freshman Member
edited March 2020 in Smart Home Product
I need some help with port forwarding on my EMG3425...
All of the guides I have come across show a NAT/Port Fowarding page that looks nothing like mine does, mainly that the field "Translation Port" is not present anywhere except my router.
I have a static IP setup with my ISP, and that is active, and I am trying to setup a VPN using port 1194.
The VPN server has been set up and has been assigned a static IP of 192.168.1.4 in my network.
When I attempt to setup my forwarding rule, using 1194 as both the port and translation port, I can never see it open from the outside.
What am I missing here?
#SP_Mar_2020
  • HouliCrab
    HouliCrab Posts: 41 image  Freshman Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Hi NClack,
    May i know your Firmware Version ?
    Based on my experience, the port forwarding page should here " Configuration-->Network > NAT > Port Forwarding"
  • NClack
    edited March 2020
    Where can I find my current firmware version?
    Looking through the entire menu I cannot find an entry for current firmware version, only the option to update firmware.
    Port Forwarding IS Config > Network > NAT > Port Forwarding
    My issue is that no matter what I set, I cannot open a port to the outside
    I found it
    V1.00(AAYJ.13)C0_20180921
  • BrazilKing
    BrazilKing Posts: 3 image  Freshman Member
    Hi NClack,
    I also have one HTTP server on port 1194, you can refer my setting below
    Hope this could help you.
