VMG3925-B10B in Bridge/Modem Only mode from LAN with single cable
sebus
sebus Posts: 4 image  Freshman Member
edited March 2020 in Smart Home Product
I am trying to get to Zyxel VMG3925-B10B in Bridge/Modem Only mode from LAN driven by Mikrotik router
So the setup is client (wired or wireless) --> Mikrotik Eth1 --> single cable to VMG3925-B10B Eth1
From LAN client (192.168.88.1) I can ping the newly created Vlan2 interface on Mikrotik (192.168.2.1), but not the home networking/group interface on Zyxel (192.168.2.10)
Vlan2 is "attached" to Mikrotik Eth1 (which is used for PPPoE connection to Zyxel Eth1)
</code><code>1 - login to UI of zyxel
2 - select networks -> vlan groups
3 - add group called bridge set vlan id to 2, tick the include box on the lan port you want to use (one used for wan)
4 - select networks -> interface grouping and assign bridge vdsl port to same lan port.
Note you may have already done steps 3 and 4 when setting up the bridge.
5 - now select networks -> home networking
6 - in group name box default is preselected, change this to bridge
7 - make a note of the ip address shown, change if you want to. (to keep things simple change it to 192.168.2.10
If I add ie Eth4 to Vlan Group on Zyxel (point 2 above), then connecting directly on that Eth4 I can access Zyxel unit via that IP, so it does work (just not the two together, yet)
I can not ping Zyxel from Mikrotik itself either
</code><code>[admin@MikroTik] > ping 192.168.2.10
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.2.10                                            timeout
    1 192.168.2.10                                            timeout
    2 192.168.2.1                                84  64 982ms host unreachable
    3 192.168.2.10                                            timeout
    sent=4 received=0 packet-loss=100%
Nothing from Zyxel to Mikrotik either, must be something to do with Vlan setup (most likely)
</code><code>ZySH> ping
BusyBox v1.20.1 (2019-05-06 17:42:59 CST) multi-call binary.
Usage: ping [OPTIONS] HOST
Send ICMP ECHO_REQUEST packets to network hosts
        -4,-6           Force IP or IPv6 name resolution
        -c CNT          Send only CNT pings
        -s SIZE         Send SIZE data bytes in packets (default:56)
        -t TTL          Set TTL
        -I IFACE/IP     Use interface or IP address as source
        -W SEC          Seconds to wait for the first response (default:10)
                        (after all -c CNT packets are sent)
        -w SEC          Seconds until ping exits (default:infinite)
                        (can exit earlier with -c CNT)
        -q              Quiet, only displays output at start
                        and when finished
ZySH> ping -4 192.168.2.1
^Ccommon_ping: hostname 192.168.2.1
PING 192.168.2.1 (192.168.2.1): 56 data bytes
--- 192.168.2.1 ping statistics ---
11 packets transmitted, 0 packets received, 100% packet loss
ZySH> ping -4 -I 192.168.2.10 192.168.2.1
PING 192.168.2.1 (192.168.2.1) from 192.168.2.10: 56 data bytes
5 packets transmitted, 0 packets received, 100% packet loss
Does this unit tag the output of the switch ports (in that config)?
I have no idea, it didn't seem to when I tried.
Anybody has any ideas?
sebus
#SP_Mar_2020
  • sebus
    I see, nobody has any clue how Zyxel products work...
