How to enable Samba log
Andreas_E
Andreas_E Posts: 1 image  Freshman Member
edited July 2018 in Personal Cloud Storage
how can i enable the SMB-Log on NAS540/542?
I have tried to edit the smb.conf under /etc/samba/ and add follow lines:
log file = /var/log/samba/%m.log
max log size = 10000
log level = 2 smb:4
With a restart from the NAS the smbd should now log the accesses from the Clients but the changes in smb.conf are undone.
With friendy Greets from Germany.
#NAS_July
«1
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    edited July 2018
    Maybe you can use the Samba tweak in Tweaks
  • Varfalamey
    Varfalamey Posts: 8 image  Freshman Member
    Up. Nas-Central down.
  • Alex M
    Alex M Posts: 5 image  Freshman Member
    what's the default password for Samba account?
  • Batou
    Batou Posts: 101 image  Ally Member
    Hi Alex M,
    It depends on which user account you used, the password is the same as that account's setting.
  • Varfalamey
    Mijzelf, is there any syslog-ng tweaks? Cause any reboot sets to default syslog-ng.conf.
  • Mijzelf
    No. But if you have a script which does the necessary adjustments, and you have RandomTools installed, you can put that script in
    /i-data/sysvol/.PKG/RandomTools/etc/custom_startscripts/
    to get it executed on boot.
  • Varfalamey
    OK. I'll try. Thank you!
    And there is one problem at NAS542. After rebooting NAS smbd starts without using "smb.conf.Tweaks" config file. Process is "/usr/sbin/smbd -D" for each user.
    I reinstall Tweaks via AppCenter (when installing it lags at 98%; need to press cancel, reboot NAS and install Tweaks again) and enable Samba tweaks. After that smbd starts with a process "/usr/sbin/smbd -D --configfile=/etc/samba/smb.conf.Tweaks".
    Is there any way to solve that problem?
  • Varfalamey
    Looks like after reboot samba.sh from /i-data/sysvlo/.PKG/Tweaks/gui/Tweaks/plugins doesn't exec at startup
  • Mijzelf
    The Samba tweak creates the file /etc/samba/smb.conf.Tweaks,  then patches /etc/init.d/samba.sh to add the configfile, and then calls '/etc/init.d/samba.sh restart', as you can read on line 108 of samba.sh. I don't see how that could fail (and it doesn't fail on my box)
    Why do you think so? The script is sourced from /i-data/sysvol/.PKG/Tweaks/etc/init.d/Tweaks, starting at line 338. As you can see there is a log function, which can be activated by adding a line
    touch /tmp/${PKG_NAME}.log
    somewhere above 338. Does that give new insights?
